Gas tank leak, again... - Honda RC51 Forum : RC51 Motorcycle Forums
» Insurance
» Sponsors
» Our Partners
»ATV Reviews
»Motorcycle Games
Go Back   Honda RC51 Forum : RC51 Motorcycle Forums > Motorcycle Models > 2000-2001 RC51 SP1
Thread Tools Display Modes
Old 05-29-2011, 02:35 PM   #1
Hellraiser456
Member
Default Gas tank leak, again...
So this is the third time its leaked...with they different fixes.
first was jb weld, it failed
then was this "fuel safe" gas tank sealer, it failed
then i managed to actually find this patch kit... it lasted the longest, but today, i walk out and there is effing gas all over the place.
now i can't get the gas tank welded, no one will do it. i could buy another tank, but i really am sick and tired of dealing with this problem.
Is an sp2 tank a solid fix?
or am i just missing something in the automotive world, and the terms fuel safe actually means fuel safe for a limited amount of time.
i need a new tank...i cant keep fixing this one...this patch stuff i don't even want to remove. i feel there is just to many "failed" attempts. i know the stuff was applied right cause it would last a year. my guess its the cold weather (-40*C)that makes it fail(aside from the jb weld, which the fuel actually ate away, it turned into mush). So if i can't weld the tank...what can i use to make sure this will never happen again?
Hellraiser456 is offline   Reply With Quote
Old 05-29-2011, 02:45 PM   #2
screamin chief
Senior Member
screamin chief's Avatar
Default
i went through it also for over a year with nothing working. I finally used a product from KbS coatings. it is a sealer but it has lasted 2 years (knock on wood). Go to www.KBS-COATINGS.com if your interested. i feel your pain
__________________
2000 RC51
1985 ATC 350X
2009 Silverado SS clone
Lots and lots of guns!lol
screamin chief is online now   Reply With Quote
Old 05-29-2011, 02:57 PM   #3
Hellraiser456
Member
Default
i saw things like that, the issue is, is that i think when winter comes, it gets bloody cold, and the bike get stored in an unheated garage. i believe that is what is making these chemicals fail. its the only theory i got since none of them really say they are rated for that weather, all three times i have cleaned the tank, applied the stuff over the entire hinge and scraped the tank before doing so. i haven't ripped apart the tank yet as i just noticed it today, but i my guess is it will be lkike the last fuel safe stuff, it was still hard as a rock, but is peeling off. which could make sense if it saw 6 months of winter. not only that winters here are chaotic. i mean in one 24 hour cycle, it could be say -30*C during the night and then jump to +10*C during the day. and it could do this for a few days, then just go back to staying cold, which i have seen temps of -50*C. and its those days that i have trouble getting my car started, and its a ford. So my theory is that its just expanding and contracting too much and breaking lose from the tank, then is tart riding and tossing the bike around, hitting bumps, and it just makes its way back to the hinge and starts leaking again. that's all i got. the chemicals themselves aren't breaking down.
its a hazard, and i need my bike because i use it as a second vehicle to get to work when someone else (my gf) is using my car. and i hate riding it when its liek this cause its dangerous and its a waste of precious gas.
point being i would love to try this stuff, but will it really handle the environment out here.
Old 05-29-2011, 03:08 PM   #4
jondog9
jondog9's Avatar
Default
I got my bike with that failed sealer all gummed up in the tank. Plugged the filter and burned the pump. I thot the only chance of a perm fix was welding. It worked. I could reach in the tank pretty good, clean out all the gook, and scuff out most of the rust. Seems like only the lower part of my tank was affected. I used the wasted fuelpump/flange as a cap later to pressure test the tank after welding. My favorite radiator shop did all the welding and testing. Cost abot $100. But he showed me the ta-k holding a little pressure. So i scuffed the inside as best i could, including putting the scotchbrite on the end of a paint stick. Washed it real good, replaced pump and filter assy with one found on craigslist, and so far, so good. Been about 6-8 monhs.
Oh yeah, burn from welding was minimal. Could have gotten away without painting cause the seat covered it all up.
If you know a good rad shop, you could do the rest, but consider the burn factor.
__________________
john, 2000 RC51 #000100
jondog9 is online now   Reply With Quote
Old 05-29-2011, 03:21 PM   #5
Hellraiser456
Member
Default
i'll look into that.
is it true that the sp2 tanks are significantly less prone? i also read some where on this forum that there was a recall...but the guy was looking for information on it.
i would love to weld it, but i never thought of the burning the paint...i know for sure that it is just around that hinge. there were two rust spots inside the tank and i figured that was the source of the leak. the last stuff i used was almost a fiber glass, you laid this patch down and then applied a resin almost. it was nasty and didn't smell very good. i had to use gloves with it. my i try to see if there is a place that speciallizes in gas tank repair or something. i have called all the main bike shops and they won't do it, and the honda stealership offered me a new tank for like 1500 bucks. I must say that honda really pisses me off when it comes to parts, like why they won't let other shops sell parts is beyond me. but that's a whole other story, and i don't even wanna get started on that.
maybe i will talk to a welder at work... see what his opinion is. he is an excellent welder and may be able to point me in the right direction, if he can't do it himself.
can you show me the paint damage? is it anywhere visible? i wasn't going to do all that till next year. this year its the clutch, sprokets, chain and ignition. next year is making the bike look really nice. this freaking machine is becoming a headache. it sucks that i love it so much.
Old 05-29-2011, 03:47 PM   #6
jondog9
jondog9's Avatar
Default
Be aware it doesnt take much off that stuff to plug your filter. And a filter is pretty hard replace. Assuming your pump survives starvation, which it wont for long. Used pump and filter assy will cost $200 or under, i had no problem finding several to choose from.
General knowledge is SP2 tanks never suffered the leaky weld.
Use the advanced search to find gas tank posts and define my user name if you want to see pics. I got a few up. Sorry, i am crippled on my smartphone for the moment and dont know how to upload pics from another source.
__________________
Old 05-29-2011, 04:15 PM   #7
Hellraiser456
Member
Default
^^ no worries, i may just see if i can find a sp2 tank then, that sounds easier. like i said, i am pretty much done trying to fix this issue as its been an issue three times. if not, or maybe in the mean time i'll just get it welded. then use that sealer stuff to finish the job. like i said i am probably going for a custom paint job next year with new fairings, so as long as it doesn't look horrible i won't care.
as for the fuel pump starvation, no issues yet, but i check for that leak nearly every time i get onto the bike, so i catch it quick.
Old 05-29-2011, 05:38 PM   #8
screamin chief
Senior Member
Default
the kbs stuff was a 3 step deal. 1st cleaned the tank. 2nd acid etched the tank. 3rd was almost a epoxy paint. $40 problem fixed. I know im not in canada but over the winter it is in the single digits in my garage. no issues. You just slosh each step in the tank. this stuff will work on very rusted tanks it is pretty hardcore. I dont work for them or anything but it did work.
__________________
2000 RC51
1985 ATC 350X
Old 05-29-2011, 05:53 PM   #9
badboyrr
Member
badboyrr's Avatar
Default
My 2000 did the same thing. I took it to the local Honda dealership, talked the the service manager about my leak. He spoke to the Honda rep. and had it replaced for nothing.
badboyrr is offline   Reply With Quote
Old 05-29-2011, 06:59 PM   #10
jondog9
jondog9's Avatar
Default
Quote:
I've heard of this once before, but I hit a solid brick wall in my efforts. Got no love at all from Honda Service or my dealership.
__________________
You may not post new threads
You may not post replies
Forum Jump
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Motorcycle News, Videos and Reviews
Ducati Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
