Choke on an 04?? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 11 (permalink) Old 11-12-2010, 07:13 PM Thread Starter
Choke on an 04??
Ok, I'm new to an RC51 and a v-twin bike in general...while putting cans on the 04 that I just bought I looked up and saw a choke??
Ok, I don't think I'm a complete idiot, but I haven't known a FI engine to have a choke?
What am I missing?
osumason is offline
post #2 of 11 (permalink) Old 11-12-2010, 07:55 PM
erbgottie's Avatar
It's not a "choke", it's fast idle.........It's a circuit that allows the engine to up the RPM's for warm up. Chokes change the air/fuel mixture for warm up on carbs. The RC has a very "cold" engine period and the fast idle def helps.
erbgottie is offline
post #3 of 11 (permalink) Old 11-12-2010, 07:59 PM Thread Starter
ok...got it.
I knew it had to be something else...I just about flipped out thinking the bike had an engine swap done with one with a carb and I wasn't told!!
Thank you, I would have looked it up in the owners manual, but somehow the previous owner lost it.
osumason is offline
post #4 of 11 (permalink) Old 11-12-2010, 08:03 PM
erbgottie's Avatar
It's all good, when I got mine last Aug I thought the same thing, but quickly figured it out. no problem bud, that's why the forum is here.
2003 Honda RC51 - 46K+
post #5 of 11 (permalink) Old 11-12-2010, 09:38 PM
how should this fast idle be utilized?
RC51-Dream is offline
post #6 of 11 (permalink) Old 11-12-2010, 10:32 PM
Ick
Ick's Avatar
Check the manual - I think it tells you to not use it for very long. I use it for about 30 seconds.
R6
919
Ick is offline
post #7 of 11 (permalink) Old 11-12-2010, 10:54 PM
I usually pull it out all the way to start a cold engine.
As the engine warms and the revs increase, I gradually push it in until it's fully seated with the engine at normal idle RPM.
post #8 of 11 (permalink) Old 11-13-2010, 10:04 AM
erbgottie's Avatar
well, it all depends on the temp outside of course, if it's hot then obviously not long, like subsailor said enough to get it warm. I've ridden in to work on days where it's 20 deg outside and that takes a lot longer prob 5-7 mins on fast idle.
post #9 of 11 (permalink) Old 11-13-2010, 06:20 PM
Why does the manual call it a choke? I was flipping through looking for a wire diagram and did see those words...
post #10 of 11 (permalink) Old 11-13-2010, 09:18 PM
Probably because most folks don't grok the "fast idle" description.
