Actual mileage?? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 12 (permalink) Old 04-03-2013, 09:42 PM Thread Starter
TORQUEDORK's Avatar
Actual mileage??
So i got to thinking...
My bike doesn't have a speedo healer(not really a big deal to me) as i dont do high speeds anyways
But how does that affect my mileage
Since the speedo reads higher than "actual" mileage, i assume im clocking miles iv not actually ridden.
How would i calculate the difference? Anyone?
Oh...and having geared down last year(15/41) i assume i made it worse...
2006 #215 PC3USB
soft rev, flapper, 15/41
TORQUEDORK is offline
post #2 of 12 (permalink) Old 04-04-2013, 05:59 AM
Andrew's Avatar
You need to find out the difference in actu al speed vs. Displayed. We will assume an average of 10 mph to keep math easy. Take your total mileage and divide by 10. Take that number off the total number of displayed mileage.
Andrew is offline
post #3 of 12 (permalink) Old 04-04-2013, 08:20 AM
First step is determine how far off your speedometer is. If you have access to a GPS you can do that or use an online calculator like http://gearingcommander.com/
So 15/41 gearing is pretty common and looking at the calculator when you're going 60mph with that gearing, your speedometer should be reading about 65.6mph. That's a little more than 8.5% difference. So you can roughly figure on adding 8.5% more miles on your odometer for as long as you run this gearing without running a speedometer calibrater.
So running non-stock gearing without a speedohealer (or similar device) does cause your odometer to rack up miles different than the actual miles traveled. It's also not a huge deal to some, but I can't stand my speedometer not telling me what my actual speed is too.
dasrider is offline
post #4 of 12 (permalink) Old 04-05-2013, 08:13 AM
Hig
Hig's Avatar
When the grand scheme of things are considered, the actual extra mileage is a pretty small number when you consider that people look at on vehicles. They generally think in terms of thousands/ten throusands. If you ride 20k you will tack on less than 2K of extra miles.
But yeah, if you know the mileage of the bike when you swapped gears you can easily deduce the new real mileage with some math. There is a surprisingly accurate ap for the iPhone called speedtracker and I used it to set my speedo with the speedo healer...it even has a sweet HUD mode that I am going to try out with the bike...worked in the car so far.
Hig is offline
post #5 of 12 (permalink) Old 04-05-2013, 09:09 AM
Rogue has a gearing calculator. You can use it to determine actual speed at rpm and gear, and check against what your speedo says.
Remember the bike stock was already overestimating speed and mileage, generally around 5-7% in my experience. So with a change in sprockets it gets worse too.
post #6 of 12 (permalink) Old 04-05-2013, 10:01 AM
Hig
Hig's Avatar
FWIW, I remember that my correction with a 190/55 and 15/41 gears was around 12.3%.
Hig is offline
post #7 of 12 (permalink) Old 04-05-2013, 12:03 PM
Well, maybe that's an example of the inconsistency of OEM speedo readings.
I have the same 190/55, but 15/42, and my correction factor was only 11%. Checked against my GPS.
post #8 of 12 (permalink) Old 04-05-2013, 01:14 PM
Hig
Hig's Avatar
Indeed, also a factor is air pressure, tire brand, etc...considering the difference between ours it's most likely one of those minor factors.
I used GPS as well and may have even rounded some numbers here and there. Verification with GPS has been spot on though (+/- .2-.4 MPH)
Hig is offline
post #9 of 12 (permalink) Old 06-06-2013, 02:43 AM
JonPowerShift's Avatar
I still have the stock gearing (16/40) 190/50 pilot and my speedo is way off I'm always on the freeway and I always pull next to cars an check my mph,. What do u guys suggest for accuracy
JonPowerShift is offline
post #10 of 12 (permalink) Old 06-06-2013, 11:50 AM
JusAnadaMexican's Avatar
Speedhealer....
2001 rc51 upgraded
2006 650R Ninja sold
JusAnadaMexican is offline
