Spare parts to have...
Just to have and cut down the down time when something goes bad. I'm looking to start stocking some of the parts that commonly fail.
FUEL PRESSURE REGULATOR
BOTH-16740-MCF-013
THERMOSTAT
BOTH-19300-MBT-003
STARTER MOTOR ASSY
BOTH-31200-MCF-003
PGM-FI UNIT
SP1-38770-MCF-671/38770-MCF-771
SP2-38770-MCF-A21/38770-MCF-L21
RECTIFIER, REGULATOR
SP1-30450-MCF-003
SP2-31600-MCF-D30
MOD RECOMMENDED
CONVERTER UNIT
BOTH-30450-MCF-003
COIL PACKS
SP1-Front-30501-MCF-E01/REAR-30502-MCF-D31
SP2-Front-30501-MCF-D31/REAR-30502-MCF-D61
STATOR WINDINGS
SP1-31120-MCF-003
SP2-31120-MCF-D31
PUMP ASSY., FUEL
SP1-16700-MCF-D32
SP2-16700-MCF-D61
CLUTCH MASTER REBUILD
BOTH-22886-MAT-E01
CLUTCH SLAVE ASSY.
BOTH-22860-MT7-000
REBUILD-BOTH
*PISTON-22863-MJ8-003
*SPRING-22864-MT7-016
*CUP, SLAVE CYLINDER-22865-MJ8-003
*OIL SEAL-91209-MB0-003
*GSKT, SLAVE CYLINDER-22862-MGJ-D00
FRONT BRAKE MASTER REBUILD-45530-MCF-006
FRONT CALIPER REBUILD
*SEAL SET, PISTON-06451-MA7-405
*SEAL SET, PISTON-06451-961-405
*SEAL, JOINT-45103-MR7-006
*PISTON A-45107-MAS-E02
*PISTON B-45117-MAS-E02
EXHAUST GASKET
SP1-18292-MCF-003
SP2-18292-MCF-D30
HEADER NUT
BOTH-90304-MM5-000
Any other suggestion on parts I should look for?
Thanks
James
BOTH-16740-MCF-013
THERMOSTAT
BOTH-19300-MBT-003
STARTER MOTOR ASSY
BOTH-31200-MCF-003
PGM-FI UNIT
SP1-30450-MCF-003
SP2-31600-MCF-D30
MOD RECOMMENDED
CONVERTER UNIT
BOTH-30450-MCF-003
COIL PACKS
STATOR WINDINGS
SP1-31120-MCF-003
SP2-31120-MCF-D31
PUMP ASSY., FUEL
SP1-16700-MCF-D32
SP2-16700-MCF-D61
BOTH-22886-MAT-E01
CLUTCH SLAVE ASSY.
BOTH-22860-MT7-000
REBUILD-BOTH
EXHAUST GASKET
SP1-18292-MCF-003
SP2-18292-MCF-D30
HEADER NUT
BOTH-90304-MM5-000
Thanks
James
