Cooling fan problems - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 19 (permalink) Old 05-10-2013, 12:21 PM Thread Starter
Hereís a new one for youÖ
My cooling fans were turning on at 228F and turning off at 220F. Iíve read through the service manual, nothing like this is out lined in there.
-No FI light
-Everything works and runs like it should
-I can turn them on and off with my manual switch mod.
-SP2
-Engine Ice, less than 1000 miles old, 23k on the clock
I started the bike about an hour later and let it reach temp, this time on at 219 and off at 211. Guess the problem fixed itself.
Anyone have an idea what the issue may have been? The main reason I started this thread is that Iím not sure that if itís a precursor to a future problem or not. If so, I want to take care of it now, before itís a bigger problem. But Iím guessing that water got somewhere it wasn't supposed to. I'm about to check: for water; the grounds; wires for wear; and over all condition of everything. I'll update with what I find.
Thanks for any insight,
James
post #2 of 19 (permalink) Old 05-10-2013, 04:58 PM
Open up wsm. Go to wiring section. For cooling fans check all your powers grounds. If you can take the farings off and run it hot. See if it acts up. If it does do a wiggle test with the connectors that pertain to the cooling fans sensors ect.. It's probley a bad sensor in the tstat housing .
Radrc51 is offline
post #3 of 19 (permalink) Old 05-10-2013, 05:32 PM
My initial suspicion was the ECT sensor starting to fail.
post #4 of 19 (permalink) Old 05-10-2013, 06:53 PM Thread Starter
I found water on the ECU connectors. I'm going to pull them off make sure they're clean and put some dielectric grease in the plugs.
I don't feel that it's a ground issue. My fan switch is wired in to ground the low amp side of the fan relay.
Once I get the time, I'll dig into it deap enough to check out and the ECT.
Sent from Motorcycle.com App
post #5 of 19 (permalink) Old 05-10-2013, 10:17 PM
Talk like that gives Sub a chubby....
post #6 of 19 (permalink) Old 05-10-2013, 10:22 PM
Grease for peace man.
post #7 of 19 (permalink) Old 05-10-2013, 10:29 PM
According to the manual on P.19-2, at 176 deg F, the ECT resistance should be 310-326 ohms.
And at 230 deg F, the resistance should be 139.9-143.5 ohms.
As you can see, the higher the temperature, the lower the resistance of the ECT.
Hypothetically, corrosion or tarnish on the ECT contacts would tend to add resistance to the ECT resistance value, making the ECU believe the temperature is lower then actual.
post #8 of 19 (permalink) Old 05-11-2013, 02:36 PM Thread Starter
When the man is right, he's right.
I worked as a mechanic on AAV's (Google image "AAVP7A1") for 6 years, with them sitting for half their life and in saltwater for the other half, you lean fast that those damn things won't run long with out it.
Sub, I always enjoy reading your posts, always very informative.
Thanks man.
Pulled my ECU, found some light corrosion on a few of the pins. Cleaned them off, problem still exists. On at 219 off 211
Wouldn't extra resistance from corrosion or tarnish also throw off the temperature display too?
Well...Time to pull the air box and all that mess to get to the ECT. Then figure out a way to test the resistance at 230 I wonder if my stove can push water that far past boiling.
James
post #9 of 19 (permalink) Old 05-11-2013, 10:53 PM
Thanks man.
James
Since the ECT gives the ECU the input of coolant temperature based on variable resistance, any change in resistance will alter the perceived coolant temp, and what is displayed by the ECU (which controls the instrument display).
There is the possibility that the ECT itself may be failing internally.
So if all your contacts are clean and you're still getting faulty readings or fan operation, then it might be the ECT itself. Nothing lasts forever.
The thing is, your ECU is going by what the ECT is sending, despite what the actual coolant temp is.
But your numbers are close to what the manual says.
For the SP1, Fan On is at 208-216 F, and Fan Off is at 199-207.
I'm sure the SP2 follows similar temps, though not stated.
For my SP2, it's been Fan On at 218 F, and Fan Off at 205-210 F.
Yours is Fan On at 219 F, Fan Off at 211 F.
I'm wondering if 1 deg F difference for both is ok and not worth the effort.
post #10 of 19 (permalink) Old 05-11-2013, 11:31 PM
James...as you are completing this work, how about some pictures if possible. If indeed the sensor has failed, I for one would like to see it.
