It was finished now problems - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 18 (permalink) Old 07-18-2013, 02:19 AM Thread Starter
rc51ftw's Avatar
Alright so i finished the RC, took it out for a short ride. let me preface by saying, the motor was rebuilt about 500 miles before I wrecked it about 5 years ago. It has a power commander but i no longer have the cables to re map it. Since I Put the bike back together I did the PAIR mod and put new high mount exhaust. Thats it for mods engine mods.
Problems:
1. Hard to start without the choke on.
2. engine cuts out, unless i throw it a little throttle.
3. revs sporadically under moderate throttle. Seems fine under harder throttle.
4. Noticed it smells like oil after i shut it off with a little smoke coming out of the exhaust.
Now I was going to take it to get it dyno tuned but now I think I have a big problem. Is it a valve issue? Any thoughts opinions would be greatly appreciated.
-02 RC
-02 954RR
rc51ftw is offline
post #2 of 18 (permalink) Old 07-18-2013, 02:28 AM
guessing simple things first, fuel pressure regulator. 5 years is a long time.
I think most folks have to choke at least a little to get her to run, so that's normal. Idle at 1300 once warmed up?
What PC do you have, a 3r?
post #3 of 18 (permalink) Old 07-18-2013, 02:59 AM Thread Starter
rc51ftw's Avatar
Won't idle after it warms up, real low if it doesn't die, it's a pc3, was thinking about a new pressure regulator.
-02 RC
-02 954RR
rc51ftw is offline
post #4 of 18 (permalink) Old 07-18-2013, 06:48 AM
pei-twin's Avatar
Quoted: 4 Post(s)
I had a problem similar to this a few years ago with my last rc, it ended up being my fault the airbox was not tight when I put it back on.(still don't explain the smell of oil though)
pei-twin is offline
post #5 of 18 (permalink) Old 07-18-2013, 08:16 AM
Who "built" your motor, did they go all the way through it? does it smoke at idle or under throttle? did you do your pair delete correctly? this is the big one lol, what color is the smoke?
04 Nicky
Jardine slip ons
520 conv. 15/40 RK quick accel kit
RickyBobbyv8 is offline
post #6 of 18 (permalink) Old 07-18-2013, 09:58 AM Thread Starter
rc51ftw's Avatar
Local Honda dealership did the rebuild, only smokes under throttle and when I shut it off. Did the PAIR mod per the rogue website with Kyle block off plates The smoke is bluish and smells like oil.
-02 RC
-02 954RR
rc51ftw is offline
post #7 of 18 (permalink) Old 07-18-2013, 10:17 AM
Can you test your fpr? That could explain a little of the smoke maybe...
post #8 of 18 (permalink) Old 07-18-2013, 12:05 PM
Probably more than one problem, but the common answer here is to unplug the power commander and see what happens.
That wouldn't explain the smoke though. Do you know what they did to the engine when they went through it?
Pull the plugs and see which one is fouled. if it is puffing smoke, one of the plugs at least will be black.
MikeinCtown is offline
post #9 of 18 (permalink) Old 07-18-2013, 02:29 PM
wingnutt's Avatar
Quoted: 58 Post(s)
Switch out the fuel over and out
wingnutt is offline
post #10 of 18 (permalink) Old 07-18-2013, 03:36 PM
Check the plugs and report back, the bluish smoke does indicate that its burning oil, most likely its coming past the rings since it doesn't smoke at idle.
04 Nicky
Jardine slip ons
