Turn signal issue .. - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 10 (permalink) Old 07-28-2013, 01:55 AM Thread Starter
JonPowerShift's Avatar
Hey guys I've gotta problem .. My (left)side blinkers blink perfectly fine, the orange light on the cluster works also , my (right) side blinkers are dim in the rear and the front one doesn't work , when I click the right side blinkers the whole cluster blinks , but the little orange signal doesnt blink. Any suggestions on where to start.. I've tried changing the bulb , doesn't help , any info or help would b. highly appreciated I have stock rear blinkers , and proton flush mount fronts
JonPowerShift is offline
post #2 of 10 (permalink) Old 07-28-2013, 12:39 PM
Andrew's Avatar
I would start by looking at your electrical connections for your blinkers then your blinker relay.
Andrew is offline
post #3 of 10 (permalink) Old 07-28-2013, 12:42 PM
Yeah the blinker relay works the same for either side.
The difference being the side the signal switch selects.
If it works fine for one side, but not the other, start checking the faulty side's wiring and components.
post #4 of 10 (permalink) Old 07-28-2013, 01:03 PM Thread Starter
@sub sailor/Andrew thanks so much guys , I'm gonna check all the wiring from the socket to the cluster with a voltmeter and see what I get , when they were installed (heat shrink) was used as I don't care for the bung connection..
post #5 of 10 (permalink) Old 08-07-2013, 12:33 AM Thread Starter
@subsailor , now the cluster backlight doesn't illuminate , I just ordered a whole new harness for the front , this is real frustrating as the bike is my only means of transportation ..
post #6 of 10 (permalink) Old 08-07-2013, 09:48 PM
Does your tail light work?
If you lost instrument panel illumination and operation, and tail light, you may have blown the 10A fuse E in the fuse box during troubleshooting.
post #7 of 10 (permalink) Old 08-07-2013, 10:04 PM Thread Starter
@subsailor , yes tail/brake lights works, the (turn signal indicator) (high beam indicator) lights do not illuminate on the dash neither only the (neutral /oil lights works) the cluster still reads (speed/tach/trip/odometer) jus no backlight ..when I tested the wires for the right turn signal , the voltage barely even came up on the voltmeter . That's why I order a brand new front harness , no wires or frayed/burnt corroded or nothing of that sort .
post #8 of 10 (permalink) Old 08-08-2013, 10:58 AM
Does the switch for your blinkers feel stiff or stixky? I had similar issues that your describing and blew multiple fuses in pursuit. After a while of nothing I ended up following my issue to the control/switch on the bars. Eventually I took the whole unit apart, cleaned the contacts, re greased the moving part and havent had any issues since. Not sure if it was the actual cause, but it was fuckin filthy in there and a clean seemed to alleviate my issues...
bamboojackson is offline
post #9 of 10 (permalink) Old 08-08-2013, 11:52 PM Thread Starter
@bamboo, yes sir I tried that,also replaced the whole unit/harness with 2 different brand new ones , and still the same problem , the harness jus arrived taday from
Honda , so I'm gonna install it 1st thing in the morning and go from
There ..
post #10 of 10 (permalink) Old 08-09-2013, 07:03 AM
mr305's Avatar
I've had a similar issue with mine. I found that my problem was with the turn signal switch, itself. My bike is an '02 that Ive had since new and the contacts in the switch were getting bad with age. I took it apart and cleaned up everything and lubed it up with a little di-electric grease and it works fine now.
'12 KTM RC8
JCE Exhaust
Bazzaz GP Quick Shift
Rottweiler Ram Air
'02 RC51
LadyBird Full Titanium HRC Replica Exhaust
PCIII USB
Lockhart CF Frame and Swingarm Sliders
GP Shift
Galfer Superbike Brake Lines
Turn One C/F Snorkle & Airbox With K&N Filter
Turn One Radiator Ducts w/Spal Pusher fans
Samco Radiator Hoses
Powdercoated OEM Wheels
'11 CBR1000RR Repsol Edition
Bazzaz ZFI/AFM
Taylormade Exhaust
'80 CBX
'65 CB77 Vintage Road Racer
mr305 is offline
