fuel line diameters - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 6 (permalink) Old 02-21-2014, 06:58 PM Thread Starter
fuel line diameters
does anybody know the diameter of the
fuel feeding line
fuel return line
i want to install a quick disconnect ( mainly on fuel return line ) to make the tank removal easier
R
Daytona28 is offline
post #2 of 6 (permalink) Old 02-21-2014, 07:47 PM
I measured around 4mm at the inlet to the 12mm fuel feed banjo fittings from the fuel tank and throttle body.
And I measured around 6.42 mm at the fuel return fitting, with the larger diameter nipple portion of the fitting at 7.5 mm.
post #3 of 6 (permalink) Old 02-21-2014, 07:51 PM Thread Starter
thank you ! so 5/16 connection should work for return line
post #4 of 6 (permalink) Old 02-21-2014, 07:57 PM
I'm guessing you're going to use a drybreak coupling with barbed ends (as I am).
So you need to find a coupling where the hose fits over the barbs, but the I.D. is not much narrower than the hose or fitting.
I'll be trying the Goodridge MCD04V drybreak coupling for my fuel return line.
http://4into1.com/goodridge-metal-qu...off-valve-1-4/
They also make a 3/16" version if the 1/4" version is too large.
post #5 of 6 (permalink) Old 02-21-2014, 08:05 PM Thread Starter
some like that yes...
http://4into1.com/motion-pro-quick-d...-shut-off-1-4/
post #6 of 6 (permalink) Old 02-21-2014, 08:47 PM
I saw that as well, but I went with metal as I felt heat can make plastic brittle over time.
I had actually seen the plastic couplers first and wondered if a metal equivalent was available when I eventually found them.
