RPM problems - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 10 (permalink) Old 03-03-2011, 09:59 PM Thread Starter
RPM problems
What would cause an RC51 motor to not be able to accelerate past 6.5k-7k RPMs in first second, or third gear?
laskdjn is offline
post #2 of 10 (permalink) Old 03-04-2011, 08:58 PM
Missing out or clutch disengaging??
post #3 of 10 (permalink) Old 03-04-2011, 09:30 PM
Worn clutch plates? How does it perform for 4, 5, and 6?
post #4 of 10 (permalink) Old 03-04-2011, 11:20 PM Thread Starter
Nah, it doesn't feel like the clutch is slipping. It feels like the engine is just bogging down. I can accelerate as fast as I want, it's just that once I hit 6.5k-7k rpms, she just stops producing enough power to accelerate.
laskdjn is offline
post #5 of 10 (permalink) Old 03-05-2011, 07:40 AM
Do you have a PC instead of the stock ECU? I would pull the ECU and check the connections, clean with a brush and add a little dielectric grease to them.
If you do pull the tank, make sure the throttle body bolts are tight. A new fuel filter is also a "cheaper" option and probably wouldn't hurt.
The US supply of gasoline is some dirty shit if you take a closer look at it.
post #6 of 10 (permalink) Old 03-08-2011, 10:22 AM
Send a message via AIM to Mystykalbaby Send a message via Yahoo to Mystykalbaby
i had a friend go through that on a gsxr 750 and come to found out the ram air tubing through the fairing to throttle botties there was a leak. just checked all seals, horns, and boots and anything else that could cause pressure to not be maintained. hope that helps. if not could be timing issues. or electrical.
Mystykalbaby is offline
post #7 of 10 (permalink) Old 03-08-2011, 06:24 PM
If it were timing I believe the engine would pop and back fire more, not to mention gear pieces in your oil pan.
post #8 of 10 (permalink) Old 03-10-2011, 11:48 AM Thread Starter
Breaking everything apart today. I have a new fuel pump to install, so we'll see then.
laskdjn is offline
post #9 of 10 (permalink) Old 03-17-2011, 01:44 AM
Sometimes RPM problem often caused by a fuel shortage... Check your fuel pressure.If it's dropping off then it could be fuel pump, filter, pressure regulator.
If not dropping , then it could be spark quality, ignition timing, fuel injectors, fuel quality. Check manual and Set the base ignition timing to factory spec for that engine. What ECU are you using? Does it go lean at high RPM…
john12121 is offline
post #10 of 10 (permalink) Old 03-17-2011, 11:41 AM Thread Starter
It was either the fuel pump or fuel filter, or both. I installed a new pump/filter, as they come as one unit. Bike works awesome again.
laskdjn is offline
