Are these things really this cold blooded? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 14 (permalink) Old 04-16-2011, 12:23 AM Thread Starter
So I have had my RC for a few weeks now and it seems very cold blooded for a fuel injected motorcycle. It came with a PC3 but I am not sure if it is mapped well. When I start it, it really likes to have the fast idle/choke engaged untill I get a few blocks of driving. No matter how long I let it idle(well several minutes anyway) is will die if I take it off and rap the throttle or try to drive off.
Is this normal or should I look into getting it re-mapped?
bladeruner69 is offline
post #2 of 14 (permalink) Old 04-16-2011, 03:17 AM
when I fire my bike up ..I will let it run for 20 sec on Fast idle/Choke ..and after that ..I will close the Choke and go in the house for several minutes to put my Jacket and helmet on .. to take off for the first time.,,I have to play with the clutch else it will die.
Color01 is offline
post #3 of 14 (permalink) Old 04-16-2011, 06:55 AM
Idrivetoys's Avatar
i just let it idle with a little choke until it reads a temp then its all good
Idrivetoys is offline
post #4 of 14 (permalink) Old 04-16-2011, 07:34 AM
I would check the throttle body bolts to the intake. Check the air box too to make sure it is sealed well. I had an issue earlier this year and found that the idle screw was out too far not allowing the engine to run at idle without the choke out.
post #5 of 14 (permalink) Old 04-16-2011, 10:36 AM
GEARHEAD69's Avatar
Mine 30 seconds choke then like color01 said get helmet,jacket, gear and don't forget ipod by then shes ready!! I thought the same thing when I switched over from the CBR (which is ready in minutes) mine will spit every once in a while if you don't let her warm up...
2000 RVT 1000R
Scorpion high mount shorties
custom paint/powdercoated wheels
flapper/pair delete
Titax quickset levers
K/N filters
Vortex chain,sprockets and frame sliders
apex cone HID conversion
GEARHEAD69 is offline
post #6 of 14 (permalink) Old 04-16-2011, 10:55 AM Thread Starter
So do any of you leave the choke on for the first few minutes of riding?
post #7 of 14 (permalink) Old 04-16-2011, 11:00 AM
Quoted: 41 Post(s)
no you are not supposed to ride with the choke out. sounds like you have an issue. i literally only use the choke for startup and shut it after about 10 seconds, then let it sit idling for a minute or two. On cold days it sits open for about 15 secs.
Check your idle screw and your pc3 map/connections. sounds like your map might be messed up.
gts455 is online now
post #8 of 14 (permalink) Old 04-16-2011, 11:11 AM Thread Starter
Ok, thanks for the help.
post #9 of 14 (permalink) Old 04-17-2011, 02:18 AM
jsteele90's Avatar
Send a message via AIM to jsteele90
yep i just put the choke on until i see a temp on the gauge then let it idle. by the time its around 110 or so im ready to roll
2003 RVT1000R
Jardine Duals
PC III
2000 Camaro Z28 [email protected] h/c/stall
jsteele90 is offline
post #10 of 14 (permalink) Old 04-17-2011, 07:46 AM
I let the bike idle to 2500 rpm with the choke on and after that I let it idle on its own until it reaches 125 degrees before pulling off.
kpowe1 is offline
