Dyno Results - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 8 (permalink) Old 04-16-2011, 02:07 PM Thread Starter
raleighp's Avatar
Dyno Results
Well the results are in ....not too bad for a 01
Hp - 119.22
Torque - 69.63
Speed - 170.02
I have some work to do, and I think getting a PCIII is my first step towards gaining what little Hp's are available. Not really thinking about any hard core engine mods at this time. Just looking to have a good reliable bike with some "get up and go!"
I did notice while on the dyno at about 9200 RPM there was some popping and a bit of flame...not sure what that was all about ( I suspect it was some type of rev limiter )but since I do not track ride or push the rpm's that high I will not worry about it now.
Will scan in the pages and post the images later...but for now I am happy !
Raleigh
raleighp is offline
post #2 of 8 (permalink) Old 04-16-2011, 07:50 PM
OUTINFRONT's Avatar
Pretty good congrats..
OUTINFRONT is offline
post #3 of 8 (permalink) Old 04-16-2011, 10:26 PM
Quoted: 41 Post(s)
nice, have you done the flapper valve, pair removal, air filter, soft rev mods? if not do them then get the PCIII. the PCIII will smooth everything out.
gts455 is offline
post #4 of 8 (permalink) Old 04-17-2011, 09:37 AM Thread Starter
raleighp's Avatar
Hey GTS - Can you explain to me what these are ??
flapper valve - when I read up on this I understood this to be for track bikes only ?
pair removal - My wife keeps my pair with her at all times...;-)
air filter - Great idea, which do you suggest ? I think it has a K&N, but I should check
soft rev mods - What are these
raleighp is offline
post #5 of 8 (permalink) Old 04-17-2011, 12:07 PM
Quoted: 41 Post(s)
no problem
flapper valve removal is fine for street bikes. Basically Honda fitted the street bikes with this flapper valve that acts as noise control to pass EPA standard. it utilizes a vacuum that closes the valve around 5000-7000 (hence a small dip in power). removal of this smoothes it out. here is a link which explains it much better.
http://rc51.org/valve.htm
Pair removal- mostly weight savings and clutter removal.
http://rc51.org/pair.htm
TPO and Kyle racing make 15 dollar kits that provide block off plates for both the pair removal and Flapper valve removal.
Chances are if your not the original owner both these have been done already. take a look at the pictures, if you see block off plates on your snorkel and on your valve covers.....its been done.
Air filter- easiest one. it utilizes the stock air filters. no need to buy anything....in fact on these bikes aftermarket filters in the stock airbox actually decrease performance due to the small capaciy of the stock airbox. All you have to do is take a dremel and cut the wire mesh off the filters, will help them breathe a bit better.
http://rc51.org/airf.htm
Soft rev mod- Your bike is capable of running higher revs, for some reason all the US spec bikes got a rev limiter that limits the redline. i'm sorry but i forgot the exact numbers. its perfectly safe to do, unlike other bikes. this bike was designed to run up to a higher RPM, as i said before all other spec bikes do not have the rev limiter....just the us version.
http://rc51.org/b2a15.htm
http://store.scottsms.com/RC51-soft-...t-RC51-SRK.htm
you can pick up parts for it at radio shack or Scotts maintenance service sells a 10 dollar kit.
gts455 is offline
post #6 of 8 (permalink) Old 04-18-2011, 09:15 AM Thread Starter
raleighp's Avatar
Here are the printed Dyno results
http://s1238.photobucket.com/albums/ff481/raleighp/
Horse Power / Torque / Top End
raleighp is offline
post #7 of 8 (permalink) Old 04-18-2011, 02:53 PM
Quoted: 15 Post(s)
i have some stock sp2 air filters available and the mesh material has been removed. if you are interested make a offer
5.4 speedster is offline
post #8 of 8 (permalink) Old 04-18-2011, 04:25 PM Thread Starter
raleighp's Avatar
Hey 5.4 ...mine is an SP-1 ....not sure they'd fit.
raleighp is offline
