Pc iii usb - ex - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 6 (permalink) Old 04-20-2011, 10:54 AM Thread Starter
raleighp's Avatar
Cool Pc iii usb - ex
hey gang, ran across this while looking for PCIII's -
http://www.motorcycle-superstore.com...C51-Parts.aspx
The EX gives the following features
Features:
Works with Any Exhaust
Increased Horsepower & Torque
Dynamometer Tested & Development Maps
Rev X-tend (a $200 value) (Increase stock rev limiter)
Individual Cylinder Mapping
Ignition Timing Adjustment
Reduces or eliminates Decel Popping
Anyone have any thoughts or ideas / suggestions ??
raleighp is offline
post #2 of 6 (permalink) Old 04-20-2011, 12:54 PM
The PCIIIUSB EX is the "street" version that complies with CA CARB/EPA regs as opposed to the PCIIIUSB "race" unit that the rest of the world buys.
post #3 of 6 (permalink) Old 04-20-2011, 03:34 PM Thread Starter
raleighp's Avatar
Hi Sub, thanks ....will I lose anything by going this route ? I like the rev extending ability
raleighp is offline
post #4 of 6 (permalink) Old 04-25-2011, 12:16 PM Thread Starter
raleighp's Avatar
Hey Sub, never got a response on this question....do I lose anything by going the EX route ? Will my bike produce less HP ?
raleighp is offline
post #5 of 6 (permalink) Old 04-25-2011, 05:39 PM
Looks like the PCIIIEX does not allow any modification to air/fuel mapping from the mid-range down. Only mid-range to full throttle re-mapping is enabled.
This makes sense on stock bikes since no emissions control is in effect at full throttle anyways.
On bikes with lambda sensors, the sensors only fine tune the engine at low to mid-throttle conditions anyways.
If your bike ran lean from low to mid, there will be no change, and with a pipe, may even run worse.
It will only run better from mid to full throttle where you can modify the air/fuel ratio.
post #6 of 6 (permalink) Old 05-02-2011, 12:16 PM Thread Starter
raleighp's Avatar
Thanks...so if I understand you correctly. I will ultimately be better off going the non-ex route for mapping purposes
raleighp is offline
