headlight help - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 11 (permalink) Old 04-20-2011, 08:51 PM Thread Starter
headlight help
ok I have a problem my highbeam doesn't work an hasn't since I bought the bike. the bulb works an I'm getting 12volts to the power side of plug but when I plug the bulb in an try it nothing. What can I check I do alot of night riding an would like my highbeam to work an I don't wanna send my bike to a shop
rockintwisties2011 is offline
post #2 of 11 (permalink) Old 04-21-2011, 03:54 AM
I would check the switch itself, I assume there is a relay to check that too.
mondo is offline
post #3 of 11 (permalink) Old 04-21-2011, 08:51 AM
skinnyshins's Avatar
Have you held the hi Beam bulb in your hand and inspected it. Some after market types will not work and fry when connected. Looks like cotton candy in there. You have to use specific bulb ranges. Check cycle world on line for a quality application in bulbs. the right quality aftermarket brand will work like daylight. No skin contact on bulb surface either use clean rag or glove.
skinnyshins is offline
post #4 of 11 (permalink) Old 04-21-2011, 09:15 AM Thread Starter
bulb is in working order I've put power to it outside the bike an it works
post #5 of 11 (permalink) Old 04-21-2011, 09:23 AM
Understood. Do you get blue indicator on cluster?
post #6 of 11 (permalink) Old 04-21-2011, 09:29 AM Thread Starter
I get blue indicator when the bulb isn't plugged in asoon as I plug the bulb in the indicator goes out
post #7 of 11 (permalink) Old 04-21-2011, 10:16 AM
I looked at schematic. Green wire is shared with low beam bulb and Hi, and blu/bk is shared from headlight relay to both Hi bulb and on to cluster. Blue wire goes from headlight handlebar switch to relay. Blk/red goes to fuse and engine starter switch. Either relay is bad or problem with handle bar switch is possible. Any other probs with handle bar controls?
post #8 of 11 (permalink) Old 04-21-2011, 11:57 AM Thread Starter
all other controls work fine
post #9 of 11 (permalink) Old 04-21-2011, 12:45 PM
Try swapping the hi-beam relay with with flasher relay to see if the relay is bad.
Many of the relays on this bike are the same type.
Usually it's opposite where the hi-beam relay is used to troubleshoot other relay problems (signal, tilt sensor, etc.).
post #10 of 11 (permalink) Old 04-21-2011, 01:24 PM Thread Starter
how do I know which relay is what?
