Dont be hatin at my lame question!! - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 4 (permalink) Old 06-08-2011, 11:40 AM Thread Starter
What does a lightweight flywheel do? Thanks!!
muffinhed101 is offline
post #2 of 4 (permalink) Old 06-08-2011, 12:08 PM
A flywheel is an energy storage device.
It takes energy to rotate the flywheel mass, and that energy is returned when the power source is reduced or removed.
The less mass the flywheel has, the less energy it takes to rotate the mass.
Some flywheel is needed to keep the engine rotating between power strokes.
It's also used to smooth out the power impulses between each cylinder.
In essence, the amount of flywheel mass is used to control the acceleration and deceleration of the engine rotation. And indirectly, the rear tire.
It's the Goldilocks engineering principle of "not too much, and not too little".
SubSailor is online now
post #3 of 4 (permalink) Old 06-08-2011, 04:23 PM Thread Starter
so does it reduce engine breaking when downshifting? Like make it more smooth going in and going out of corners or something? How does it translate to the street for the average rider?
post #4 of 4 (permalink) Old 06-09-2011, 09:07 AM
The amount of flywheel mass affects the rate at which the engine increases or decreases RPM.
It's similar to a heavy car and a light car with the same power.
The heavier car will not accelerate as quickly as the lighter car, nor slow down as quickly.
A heavy flywheel can slow down the amount of acceleration out of a corner or from a stop or during gearshifts.
A light flywheel allows rapid acceleration of the bike, but if too light, the engine can accelerate so quickly that the tire can lose traction and spin up.
Nowadays, F1, MotoGP, and WSBK use traction control to control that, so they can use small amounts of flywheel mass for quick engine acceleration.
The flywheel and clutch diameter on a F1 car is smaller than most bikes (about 6").
For downshifts, a heavy flywheel will resist allowing the engine to match speed with the rear wheel, and might cause the rear tire to lose traction.
These days, slipper clutches moderate that effect.
The same can be said for shift changes as the engine resists matching RPMs with the next higher or lower gear.
When I changed out my steel clutch plates for aluminum Hyperplates, I immediately felt a difference in shifting. Far smoother and easier due to less mass in the clutch assembly.
Singles and twins use heavier flywheels than multi-cylinder bikes since their rotating components have more mass (pistons, cranks, etc.). The extra flywheel mass smooths out the power pulses.
Multi-cylinder engines have lighter components and the power pulses are smaller and occur more often than singles or twins.
They can use lighter flywheels.
As an example, I have an RC51 and an FZ1.
Both are 1000cc engines, but I have to downshift 2 gears to get the same engine braking effect I get just by rolling off the throttle on my RC51.
There's less rotating mass on the I-4 than my V-2.
