Fuel Light pt. 2 - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 6 (permalink) Old 06-10-2011, 08:34 AM Thread Starter
raleighp's Avatar
Fuel Light pt. 2
Hey gang,
I noticed on my ride in this morning that if I get to 7200 - 8k RPM's my fuel light that is constantly on goes off. Could this be due to a loose connection ?
raleighp is offline
post #2 of 6 (permalink) Old 06-10-2011, 09:45 AM
Could possibly be vibration is causing an intermittent problem.
Wouldn't hurt to check the connectors, plus putting a dab of dielectric grease on the contacts to prevent corrosion/oxidation of the contacts.
Also, be careful when you lift the fuel tank as the main wire harness passes very near the tank and has caused many a pinched or broken wire.
post #3 of 6 (permalink) Old 06-10-2011, 09:49 AM Thread Starter
raleighp's Avatar
Thanks Sub....that makes sense. This all started right after I got my plugs changed, so I suspect there is a wire that is pinched.
raleighp is offline
post #4 of 6 (permalink) Old 06-10-2011, 10:16 PM
If you mean 7-8000rpm acclerating hard, then it could be the fuel is forced to the back of the tank, the level sensor is then not reading low level for a few seconds.
mondo is offline
post #5 of 6 (permalink) Old 06-10-2011, 10:58 PM
Quoted: 41 Post(s)
yep, happens to me on all my bikes. One way to tell for sure is if it does it after filling the tank.
gts455 is online now
post #6 of 6 (permalink) Old 06-23-2011, 12:02 PM Thread Starter
raleighp's Avatar
Problem solved....it was a pinched wire. Guess I will take the money I was going to use for a Fuel Pump and use it someplace else.....
raleighp is offline
