forks - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 8 (permalink) Old 06-28-2014, 11:15 PM Thread Starter
forks
going to remove the forks myself to save a little labor money when i take them to get my seals replaced.
read the manual, looks pretty straight forward on removing them, but re-installing them. now, i know that the fork index line needs to be flush with the top clamp for correct fork height, but i guess im not understanding how to make sure the forks are turned in the correct position
thaddeus is offline
post #2 of 8 (permalink) Old 06-28-2014, 11:59 PM
weyrauchrc51's Avatar
Quoted: 10 Post(s)
Not sure how the others do it, but you could use something like a marker or chalk to mark the fork and triple...then just match the lines during re-install.
Also...the bottom of the forks might have stickers, make sure they are in the same position.
For me, installing my new forks I initially used the stickers on the outer tubes to line them up. Then I adjusted the preload to fully closed...then matched them from there.
Again, some of our more knowledge able members will have a more correct method.
2001 SP1 (sold)
2004 SP2 (properly stored)
2012 Ruckus (stolen)
Semper Fidelis
weyrauchrc51 is offline
post #3 of 8 (permalink) Old 06-29-2014, 12:12 AM
Rossco's Avatar
Quoted: 4 Post(s)
hmm, when I did mine I used the cir clip/wire to use to get the height right as it sits up against the lower triple tree as you've said, but the way the forks faced I didn't think mattered because the lower part moves..? correct me if Im wrong. by lower part i mean the part the calipers bolt to and the wheel bolt goes through....
Now there is a way to seat the wheel correctly when tightening the pinch bolts thats what I think is the most important.
PARTS FOR SALE!
Rossco is offline
post #4 of 8 (permalink) Old 06-29-2014, 12:25 AM
Quoted: 10 Post(s)
As long as the suspension settings are the same, performance shouldn't be impacted...but I like my stuff to be symmetrical or the same. So if you didn't line up the forks, for example you could fully close the preload settings...and (using a wrench starting at the same 9 o'clock position)...could have one fork closed at 12 o'clock, and the other at 3 o'clock. Again, performance not impacted...but for me it would be weird.
2001 SP1 (sold)
Semper Fidelis
post #5 of 8 (permalink) Old 06-29-2014, 12:33 AM
Rossco's Avatar
Quoted: 4 Post(s)
Good point I hadn't thought of that, my OCD is now going to kill me lol
PARTS FOR SALE!
Rossco is offline
post #6 of 8 (permalink) Old 06-29-2014, 12:41 AM
Quoted: 10 Post(s)
forks
Haha...its gets the best of us. It is just something I noticed and adjusted when I recently installed my new forks so I thought it made sense to make them the same.
Again, I could be completely wrong though
2001 SP1 (sold)
Semper Fidelis
post #7 of 8 (permalink) Old 06-29-2014, 12:52 AM Thread Starter
so the lower part of the forks rotate? i like the chalk idea, i just figured the manual would have indicated a index line for the correct rotation of the forks as well
thaddeus is offline
post #8 of 8 (permalink) Old 06-29-2014, 12:37 PM
Yes, the lower tube will spin all around once you remove the fork leg from the bike.
And who ever mentioned about just butting the outer tube w/cir-clip up to the bottom clamp_ that's what I remember doing also.
Lastly, it was mentioned about correctly mounting the front wheel. There's a procedure that b.miller123 brought to the forum. I reprinted it in the "How To" forum.
https://www.rc51forums.com/forums/showthread.php?t=39105
