Tire removal/installation on rim - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 10 (permalink) Old 07-25-2014, 03:56 PM Thread Starter
Quoted: 7 Post(s)
I like to do things on the cheap if it means doing the same job of an expensive tool. I've seen videos on youtube about removing and installing a sportbike tire without a $2000 machine. I have absolutely no experience in this method; however, are the methods on Youtube viable? I am looking into investing into a wheel balancer as well. The price of a wheel balancer should offset the cost of tire service and balancing right?
Tanks all
penn542 is offline
post #2 of 10 (permalink) Old 07-25-2014, 04:22 PM
Rossco's Avatar
Quoted: 4 Post(s)
Hmm, I've seen tools at Harbor Freight that will do the job for removal, as for a balance, last time I went to my local bike shop they showed me some stuff in a bottle and swore by it and was telling me that it balances better then they could on the machine. They charge $25 a wheel to change tires and balance which isn't bad, I could probably change my own tires but don't want to ruin my new powder coated rims.
Ride on
Theres also beads you can put in there but I'm probably going to try the ride on.
PARTS FOR SALE!
Rossco is offline
post #3 of 10 (permalink) Old 07-25-2014, 05:47 PM
Yes, the cheap way to do it is very viable. Get some spoon tire irons, your axle and two jack stands for balancing. A lot of people will only spoon on their own tires as most shops will do it without care and patience and end up scuffing the rim.
Rossco, when i read "they showed me some stuff in a bottle" i thought they were yanking yer chain. I googled it however and its a real thing! Im only mildly impressed however...lmao.
bamboojackson is offline
post #4 of 10 (permalink) Old 07-25-2014, 06:43 PM
Rossco's Avatar
Quoted: 4 Post(s)
Haha I had to ask them twice because I thought they were taking the piss and then he showed me the bottle...
Sent from Motorcycle.com Free App sucks balls!!! Omfg it won't stop opening the f'in App Store!
PARTS FOR SALE!
Rossco is offline
post #5 of 10 (permalink) Old 07-25-2014, 07:03 PM
What you should buy: 1- valve core remover, 1- bead breaker, 1- 2# deadblow hammer, 3- rim protectors, 3- tire spoons, and a spray bottle of soapy water.
Although I don't have my deadblow hammer pictured, (I guess I used my 2# brass hammer that day for the bead breaker) I use it to help persuade the tire bead onto the rim as the last stretch of bead slips over the rim. Easy strikes so you don't harm the tire bead. Works a charm if you've sprayed just a little soapy water on the rim.
post #6 of 10 (permalink) Old 07-25-2014, 07:07 PM Thread Starter
Quoted: 7 Post(s)
Great pics and info Jondog!!
penn542 is offline
post #7 of 10 (permalink) Old 07-25-2014, 07:14 PM
Anytime Penn.
They're not the easiest thing to do, but it's nice knowing that no one else is going to abuse your rims.
Takes about 20 minutes per tire to remove the old and mount the new.
Also, helps immensely to have an air compressor so you can give the newly mounted tire a blast of air to seal the bead. Sometimes you have to run up to 40 or 50 psi to get that final bit of bead to pop up and seal. Then I remove the valve core again, drain the air, let the tire relax, put the valve core back in, and air it up again to the proper psi. About 30ish for my preference.
post #8 of 10 (permalink) Old 07-25-2014, 07:22 PM Thread Starter
Quoted: 7 Post(s)
So, dropping about $350 to $400 in tools including balancer stand should be worth it. Three seasons, two tire front and rear mount balance and install=$400 here in Canada. Sounds like a good investment.
penn542 is offline
post #9 of 10 (permalink) Old 07-25-2014, 07:41 PM
I bought some of my tire tools from our supporting vendor Riders Discount. They've been able to get me better prices than anywhere else I can find for just about any of the MotionPro tools on this page. I have their digital air guage, man I love that thing!
post #10 of 10 (permalink) Old 07-25-2014, 10:04 PM
This thread may help too. https://www.rc51forums.com/forums/sho...wheel+balancer
Thanks to Jondog's advice I use tire levers and rim protectors now and a wheel balancer too. I saw a used one for sale on www.vfrworld.com classifieds so you may want to check if that balancer is still not sold...
For breaking the bead I find using a couple of stout pieces of wood against a suitably strong wall fixing will work fine. Protect the wheels with wood on the underside when doing this. I think there's a Youtube link to show how this is done - on the thread above.
I also use some cloth and a ratchet strap (& cloths for protection against scratches) for helping keep the bead at the centre of the rim to make the new tires easy to lever on. Again, this is on the video too.
I have expensive carbon wheels so I don't want to damage them in any way, not even a scratch or chip. Doing with protectors & levers there's no problem. I prefer the Motion Pro protectors with a thin rope on them. Easiest to use. Once you know how to do it, it's not difficult at all. You don't need expensive or bulky tools to change & balance tires. In the long run you'll save a lot by learning how!
