Time for a new chain - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 11 (permalink) Old 07-31-2011, 07:38 PM Thread Starter
Tommysixgun's Avatar
I'm in need of a new Chain sprocket set, so I am looking for recommendations
what chain set would you guys recommend for just normal street riding and where can I get it?
Tommysixgun is offline
post #2 of 11 (permalink) Old 07-31-2011, 07:53 PM Thread Starter
I have never owned a bike long enough to have to put a chain on it. Am I going to have to buy some sort of rivit tool also? chains don't come sized-up and together do they?
post #3 of 11 (permalink) Old 07-31-2011, 08:40 PM
I just got an RK chain. I was going to buy the chain breaker ($80) and a rivet tool ($15) to cut it down and put it together, but found a shop that put it on for $50 so I figured I'll forego working on my own bike just this one time.
So far it's been great, but my last chain was kinked up like you wouldn't believe so the improvement's been pretty vast. Unfortunately my bike doesn't "engine brake" as well anymore and I keep hitting that damned rev limiter because it spins up so quickly.
raylee is offline
post #4 of 11 (permalink) Old 07-31-2011, 09:01 PM
I replaced my previous sprockets and chain with a Renthal 15T 530 front sprocket, a 41T 530 Vortex PTFE hard coated rear sprocket (have to use special rear sprockets for my Marchesini wheels), and an RK GB530XSOZ1 530 chain.
All together, they cost about $200.
I was worried that the aluminum rear sprocket would wear prematurely, but it has lasted over 15K miles with hardly any where.
SubSailor is online now
post #5 of 11 (permalink) Old 07-31-2011, 10:01 PM Thread Starter
$50 was that for the chain only or the chain and the sprockets?
post #6 of 11 (permalink) Old 07-31-2011, 10:10 PM Thread Starter
What does 530 stand for? is that like the size of the roller on the chain? I'm telling ya I don't know anything about buying a chain. whats the advantages or disadvantages between a 530 or 520 set any or it doesn't make much difference?
post #7 of 11 (permalink) Old 07-31-2011, 11:13 PM
If you want longevity and max safty, go with steel sprockets, and 530 chain. Dont scrimp here unless you really know what you're doing. You don't want that sucker to fail. 530 means a wider, stronger, heavier chain. That's what's stock. About 1 to 1.2 pounds difference in a 520 and a 530. That may sound like a lot, but I think most people would say you cant really feel the difference.
Chains dont came assembled. You couldn't get it through the swingarm if they were. Get a good quality chaintool, upwards of $50. If you've never done any kind of chain at all before, then consider a professional do it for you. Crimping the rivits right is soooooo important.
As far as gear ratio choices, 16/40 is stock. What's your riding style and how much do you wiegh? I choose spirited, 15/42. It gives quicker acceleration, but at the cost of top speed. It gives you what feels like more power if you're a heavier rider. 15/41 is common too. I've even considered a 15/43 to get just a little quicker launch, and shorter shiftpoints. I've heard someone here running that ratio.
SubSailor has lots of technical info in his post, so if you want to research it, start with the stuff he put on his bike.
My 02 cents..
post #8 of 11 (permalink) Old 07-31-2011, 11:23 PM Thread Starter
My 02 cents..
Thanks Jondog Himm 15/43 sounds good. I'm a 180lb fella So do you run a 530 or 520? I think it would be nice to save some weight.
post #9 of 11 (permalink) Old 08-01-2011, 12:18 AM
$50 for just the chain installed. I only went with the 520 setup because I already had it on the bike.
raylee is offline
post #10 of 11 (permalink) Old 08-01-2011, 12:25 AM Thread Starter
I just ordered a Renthal 520 conversion fr/Back sprockets 15/42 and a RK GB 520 GXW chain from bikebandit and a rivit tool. Hope they all match up, I just had a bad experience were I ordered front rotors and recieved two rear rotors... holy moly.
