Tire Hugger vs. Tire Size - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 13 (permalink) Old 11-09-2011, 04:02 PM Thread Starter
raleighp's Avatar
hey gang....for those of you that are running tire hugger what size tires are you running ? I ask as I am having a very difficult time getting my hugger to fit. My 190/55/17 is too tall, but I am concerned that if OI go to a 190/50/17 it might not handle as well
Thoughts ?
raleighp is offline
post #2 of 13 (permalink) Old 11-09-2011, 07:29 PM
JB's_SP3's Avatar
I'm running a 190/55 and using the TYGA hugger with no issues. I know people who track the bikes with this combination have had issues getting the tyre warmers on. Is your chain the correct length?
Jimmy
JB's_SP3 is offline
post #3 of 13 (permalink) Old 11-09-2011, 08:08 PM
Can you shim it up, like with a custom cut thick gasket? Or fab up a couple thick sheet metal shims?
I'd take the performance of the 190/55 before I changed tire sizes to accommodate the hugger. I've felt the difference (tire sizes) and it was obvious on my bike.
post #4 of 13 (permalink) Old 11-09-2011, 10:34 PM
I have a Magical Racing hugger and it fits my 190/55 fine. One side was a little close to the right "edge" of the tire, so I sanded it in a little and resealed it for clearance. That was an issue with my 190/50, the 55 fit the same so no issues for me. I'd sand or shim it if possible, and check the chain situation.
Agent Clark is offline
post #5 of 13 (permalink) Old 11-09-2011, 11:54 PM
rc51anthony's Avatar
190/55 is the best never look back
  • Moriwaki rearsets
  • Power Commander USB
  • DID 520 gold chain
  • CRG folding clutch lever
  • Flapper PAIR EVAP removed
  • Soft Rev limiter removed
  • 15/41 gears 520
  • Vortex clip-ons
rc51anthony is offline
post #6 of 13 (permalink) Old 11-10-2011, 08:43 AM Thread Starter
raleighp's Avatar
Hi guys...thanks for the suggestions. I will try and fab or have a shim fab'd before dropping down in tire size.
raleighp is offline
post #7 of 13 (permalink) Old 11-12-2011, 06:47 PM
Tyga Fitment w/ 190/55
This is a BT016 with the Tyga hugger mounted. The gap is pretty good. (It looks crooked because I could not get that big ass camera between the tire and undertail with the lic. plate one )
This is the adhesive backed foam I used to seal between the swing arm and the hugger. This foam compresses real easy but it is dense.
Here is a look from the rt side....gap looks okay to me
And another closer...you may see a little of the foam I fitted, which I will fix later.
Again, this is a Bridgestone with one season on it (which will be changed in the spring) The profiles of different tire makers are items that may concern some but what I am seeing for clearance, will have no issues later.
post #8 of 13 (permalink) Old 11-12-2011, 10:03 PM
Those chicken strips are not acceptible. Neither is that flat top tire.
Hugger looks good. Leave it to an Indyatonian to use scotchbrite as a gasket
post #9 of 13 (permalink) Old 11-12-2011, 10:33 PM
I think I did fairly well after a 3 year hiatus....that rt side was a tough one for me this year, left is perfectly roasted. Maybe next season Thats the side my bum knee is on and that will be my excuse
That damn flat spot is from these here roads, I have to ride at least 40 minutes south to get into the river valley.
Thanks on the hugger, Tyga makes it easy for sure. It makes my red brake line stand out a little too.
Leave it to a Labia Shepard to not know that folks from Indiana are know as Hoosiers.....you need to get out of Californy more
That scotch brite is some mighty handy shit....you should see what I did with the rolls of duct tape
post #10 of 13 (permalink) Old 11-12-2011, 11:01 PM
Yes, I need a hugger. After less than one year paint on my swingarm is peppered with chips.
Yea, yea, I saw the Gene Hackman movie, I know Indy is the Hoosier State. I dont know what a hoosier is tho
