sp2 triple twisted? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 2 (permalink) Old 11-21-2011, 10:41 PM Thread Starter
sp2 triple twisted?
sp2 that had been down on the left side.didnt look very bad upon inspection.your usual bar end,mirror ,upper fairing.the axle has some rash on the left side. while running down road the cycle is going straight. the upper triple has a slight twist to the right side. the stops are intact on the lower triple, clipons are not brused up.i put the front on the stand.loosen fork lower pinch bolts.i can rotate the axle freely.so i took loose the triple fork pinch bolts rotated the fork tube about 180 degrees. no luck still twisted. the cycle doesnt have an apparent pull either. could my triple be twisted,forks?
bls77red is offline
post #2 of 2 (permalink) Old 12-08-2011, 09:13 PM Thread Starter
with the help of fellow members.who suggested to loosen the upper stem nut. and upper fork pinch bolts, sure enough the upper must have been in a bind.it straightened rite up!
bls77red is offline
