Newbie to RC51 - air filter question - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 18 (permalink) Old 12-10-2011, 06:33 PM Thread Starter
I just purchased a 2002 rc51. It has Jardine slip-ons and k&n filters. I replaced the filters with oem units. My question is, which side of the air box does the filter with the black rubber piece inside of it go on? I couldn't find the answer using the search function. I put that filter on the left side. The one with the flapper.
I did pull the vacuum line from the flapper diaphragm and plugged it. I also completed the soft rev mod and put a 42 tooth rear sprocket on the bike.
John
John2002 is offline
post #2 of 18 (permalink) Old 12-10-2011, 07:25 PM
John
Filter with black rubber cone goes on the right side.
Since you've disabled your flapper, next time just order two left filters.
post #3 of 18 (permalink) Old 12-10-2011, 07:42 PM Thread Starter
It goes on the left side.
Since you've disabled your flapper, next time just order two right filters.
Thanks for the quick response.
John2002 is offline
post #4 of 18 (permalink) Old 12-10-2011, 10:25 PM
1971allchaos's Avatar
Quoted: 26 Post(s)
Why two right filters?? Is this just to simplify re-installation? Has for mods of OEM filters - RougeRC51 only specified removing the outer metal screen from the OEM filter....
1971allchaos is offline
post #5 of 18 (permalink) Old 12-10-2011, 10:46 PM
The parts list shows two air filter part numbers, for left and right filter.
The left filter doesn't come with the sound deadening rubber insert.
post #6 of 18 (permalink) Old 03-14-2012, 09:11 AM
McWag's Avatar
hey sub, I ordered two right filters from my local dealer and I got two with the black rubber sleeve inside it. Did they F up or is it the wrong side? Can I justg pull out the rubber part? You got a part num ber for the correct side without the rubber insert???
McWag is offline
post #7 of 18 (permalink) Old 03-14-2012, 03:13 PM
budoka's Avatar
Quoted: 56 Post(s)
Yup, I'm confused too. The parts fiche shows both right and left elements as the same: p/n 17235-MCF-D30 for an '02. '00 shows one side being 17235-MCF-000 and '05 shows one side being 17235_MCF-A20. Looks like it should be the left side but not designated left. All 3 I checked show the same p/n for the 'other' side which I assume is r/h.
'03 SP2, '09 GL1800
budoka is offline
post #8 of 18 (permalink) Old 03-14-2012, 03:16 PM
erbgottie's Avatar
I just pulled mine 2 weeks ago and the filter with the sleeve inside was on the right side if ur looking at the filters from the seat forward
2003 Honda RC51 - 46K+
erbgottie is offline
post #9 of 18 (permalink) Old 03-14-2012, 03:43 PM
John
Just pull off that rubber cone looking piece....and hey look at that they are both the same
That what I did.
James
post #10 of 18 (permalink) Old 03-14-2012, 07:03 PM
erbgottie's Avatar
^ too smart for own good, very well put
