choke lever - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 21 (permalink) Old 02-20-2012, 03:07 PM Thread Starter
lyfsux's Avatar
choke lever
Dumb questionmy choke lever seems to be a bit stiff anyone ever try to lube one of these up to free it? and also on fuel injected what exactly is this knob hooked to all my fi bikes was all electronic?
2000 sp1 number 000039
full hindle off-road exhaust
power commander
double bubble screen
sprocket swap 1 down 3 up
k and n filters
and now flapper mod thanks to rc forums
lyfsux is offline
post #2 of 21 (permalink) Old 02-20-2012, 03:39 PM
Quoted: 334 Post(s)
Stiff is fine plus you should only be using the choke knob for about 5-10 seconds max anyway.
post #3 of 21 (permalink) Old 02-20-2012, 04:17 PM
I believe it's really more of a "fast-idle" knob than a choke. I only use mine for cold starts. Then it's pushed back in right away. FWIW
oneshot onekill is offline
post #4 of 21 (permalink) Old 02-20-2012, 04:21 PM Thread Starter
lyfsux's Avatar
I just got my bike and I live in ontario so it has been cold up here warmer than usual but bought it in the winter for a better price right now snowmobiles are the premium. So mine need a little more than a few seconds than a start up I was just wonder what it was hooked to is all. Waiting for the snow to melt have nothing better to do!
power commander
k and n filters
lyfsux is offline
post #5 of 21 (permalink) Old 02-20-2012, 05:37 PM
Quoted: 41 Post(s)
yes, technically it is a fast idle. Pull it out to start and push it right back in. The cable is attached under the throttle bodies.
gts455 is offline
post #6 of 21 (permalink) Old 02-20-2012, 06:22 PM
I noticed that when I use my fast idle, which isn't much. the knob sucks itself back in just a little. Still Idles fast but not at full. Any thoughts
kpowe1 is offline
post #7 of 21 (permalink) Old 02-20-2012, 06:26 PM
Quoted: 41 Post(s)
probably just the way the cable is routed. It goes up and under the throttle bodies and probably under full pull has a little tension which slackens off. Mine used to do that as well, it doesn't matter. It's not enough to make a difference, especially if it starts fine.
gts455 is offline
post #8 of 21 (permalink) Old 02-20-2012, 07:46 PM
I do lube that cable a little, right there behind the knob. I squirt a little amsoil syn grease inside that housing as best I can. It helps but only lasts for about 3-4 months.
post #9 of 21 (permalink) Old 02-20-2012, 08:28 PM
everyone keeps saying push it right back in after firing up but what would be the downside to letting it idle high for 5 mins? it just warms up the bike quicker doesnt it?
2003 RC51 #152 of 2000
The Man Who Sleeps With His Bike
WarpSpeed is offline
post #10 of 21 (permalink) Old 02-20-2012, 08:31 PM
Fouling your plugs....it was meant to be used for the cold start and then closed off once the engine is lit.
