Running and Idle issues ? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 9 (permalink) Old 03-26-2012, 11:45 PM Thread Starter
MY rc51 starts with no issues, I choke it, I can hear the inj. prime and starts fine but once it starts and warms up the rev idle goes up and then down, it revs high around 3k and then drops down to 1.5k. After the bike warms up the choke is released and the bike will studder and stall out, NO FI CODE SHOWING UP? I hope it is something simple and not the TPS. OH and it started about two weeks after I INTALLED THE PCIII, I ran the map the correct map for my current mods, I have removed the PC III and it runs a little better but not 100%
darman is offline
post #2 of 9 (permalink) Old 03-27-2012, 12:32 AM
RC-DEVIL's Avatar
Quoted: 120 Post(s)
Dude I'm having almost the same problem look in the sp1 section some of the guys have come up with some solid stuff
RC-DEVIL is online now
post #3 of 9 (permalink) Old 03-27-2012, 02:25 AM
lift your tank, remove your airbox and take a look at your fuel pressure regulator... its on the back right side of the throttle body assembly. there is a vacuum line on the end of it. if you pull that off and its wet you have your problem. it is a common issue and a $50 fix. good luck
T04z1jz is offline
post #4 of 9 (permalink) Old 03-27-2012, 10:00 PM
Yup
https://www.rc51forums.com/forums/sho...pipe+regulator
is what she looks like.
post #5 of 9 (permalink) Old 03-27-2012, 11:08 PM Thread Starter
Sounds like what it may be considering when i run the bike I SMELL FEUL, getting it changed out this week and i will kepp everyone posted thanks for all the help, great forum
darman is offline
post #6 of 9 (permalink) Old 03-28-2012, 12:56 PM Thread Starter
trying to load up some pics of my bike but? back to the topic, changed out the FPR and still idle revs up and down, its going to the shop
darman is offline
post #7 of 9 (permalink) Old 03-28-2012, 09:47 PM
hmmmm....probably not a likely solution but have you tried disconnecting the battery for 10 minutes and "reset" the ecu. also when you disconnected the power commander did you check the plugs for corrosion/ tightness?
T04z1jz is offline
post #8 of 9 (permalink) Old 03-28-2012, 11:01 PM Thread Starter
I had the battery disconnected when I was removing the PCIII, I will look at my connections today and see if there is something loose
darman is offline
post #9 of 9 (permalink) Old 03-29-2012, 02:08 AM
I've got it.... sorry i didnt think about it earlier, but if your FPR was bad then you need to take out and either replace or clean off your spark plugs. the extra fuel will gum up your tips pretty good. try cleaning them up and see if it clears up your idle
T04z1jz is offline
