Turn Signal Issues "HELP" - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 5 (permalink) Old 05-13-2012, 09:56 AM Thread Starter
Have a 2002 SP2 that came with LED front markers that won't blink, I want the flush mounts instead of the stock stems. Any input on fixing the blinky blinky would be appreciated.
Thankx Marty
[email protected]
Thumperz52 is offline
post #2 of 5 (permalink) Old 05-13-2012, 10:38 AM
Look for a "no load" electrontic flasher unit to replace the stock flasher unit.
Sean
Sport is offline
post #3 of 5 (permalink) Old 05-13-2012, 11:03 AM
Is the problem limited to one side, or do they not blink at all?
If not at all, then it could be the switch, wiring, or flasher relay.
If they only blink fast, then that's caused by insufficient current flowing through the flasher relay.
In that case your choices are to install load resistors, or replace the OEM (thermal) flasher relay with an electronic flasher relay.
SubSailor is online now
post #4 of 5 (permalink) Old 05-13-2012, 11:35 AM
Here is an old thread telling you more...
https://www.rc51forums.com/forums/sho...+flasher+relay
post #5 of 5 (permalink) Old 05-14-2012, 09:03 AM Thread Starter
No blink at all so I'll start with a compatible relay(1st response) being that the rears are stock and the fronts are flush mount LED's. Thanks for the help!
Cheers M
