Strange turn signal problem. - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 12 (permalink) Old 05-31-2012, 11:29 AM Thread Starter
I just bought a nice 2002 RC51, my introduction thread is here. One of the attractions of this bike is that it was not as hacked up as some of the ones I looked at, but it does still have some sort of aftermarket flush mount front turn signals and I am having an odd problem. I can go through everything this weekend but I thought maybe someone has seen this before and knows right off where to look.
The left side works fine exactly like it should. The right rear turn signal is always on solid, and when I try to activate the right signal the rear light flashes fast and the front light doesn’t come on. I have a solid turn signal light on the dash all the time except when I activate the left signal then it flashes normally. The rear turn signals are stock and the wiring appears to be the standard factory harness. The front signals are flush mounted aftermarket with standard single filament bulbs and 2 wires. I put a replacement bulb in the front signal and it didn’t change anyghing.
Thanks Mike
mhr650 is offline
post #2 of 12 (permalink) Old 05-31-2012, 12:47 PM
JusAnadaMexican's Avatar
ok what you need is a Dual filament for the front with a 3 wire connection. There's a reason why, I just cant think of how to explain it any further....
2001 rc51 upgraded
2006 650R Ninja sold
JusAnadaMexican is offline
post #3 of 12 (permalink) Old 06-01-2012, 11:48 AM Thread Starter
I believe that the dual filament and 3 wire connection are only required if you want running lights and turn signals, if you just want turn signals only 2 wires should be required. Somewhere something is probably cross wired I will just have to trace it back.
mhr650 is offline
post #4 of 12 (permalink) Old 06-01-2012, 12:41 PM
soundislight's Avatar
This..
It has always been my experience that a crossed wire is at play. What I would do is disconnect all your wires on that side and try putting them back as you believe they should go..
soundislight is offline
post #5 of 12 (permalink) Old 06-06-2012, 09:12 AM Thread Starter
Got my turn signals fixed, it was a crossed wire problem but a self inflicted problem by the previous owner. The aftermarket signals use single filament bulbs so they don’t function as running lights. On the left side they were wired correctly with the running light wire not connected, but on the right side the turn signal wire and the running light wire were both crimped together into the same connector. There is no way the signals ever worked correctly for the previous owner, which will have me looking over everything else on the bike closely.
Can I do a rant about cheesy aftermarket turn signals? Almost every bike you see has some replacement lights and almost all of them are crap. I had to go to a Chinese scooter store to get a new bulb for the ones on my bike, the sockets and mounting system is total crap, there is no way these will be even close to as reliable as the factory Honda parts. The Proton signals look like they would be an exception and very high quality, but I am not ready to drop another hundred dollars right now.
mhr650 is offline
post #6 of 12 (permalink) Old 06-07-2012, 02:34 AM
TkerJker's Avatar
Put a set of Protons on this winter. LOVE them. Had several different craptacular flush mounts over the years, prob coulda bought 2 sets of Protons for what I've bought and pretty much thrown away.
'01 RC51 w/ Chinese plastics, PC2, Flapper Mod, PAIR delete, Yosh highmount, -1/+3 Gearing, Hot Bodies Undertail, Proton Fronts, Zero Gravity DB, Speedo Healer and HyperPro Damper.
TkerJker is offline
post #7 of 12 (permalink) Old 06-07-2012, 07:14 PM
Yes, Protons are a work of art!
post #8 of 12 (permalink) Old 06-08-2012, 01:14 PM
My bike came with some no-name signals front and rear that I think you can get at Cycle Gear. They lit up, but were all but useless for signaling my turning intentions to anyone.
They're super expensive, but I'll never go any flushmount route unless its Watsen Design. People will know when you're turning. I had Protons on my old R1 and they were okay, but didn't grab your attention like the Watsen's do. I had a set of Rizoma Zero-11 signals I put on back and now I feel better.
dasrider is offline
post #9 of 12 (permalink) Old 06-09-2012, 12:22 AM
When you decide to replace the front signals with better quality ones, look for the connector kits that use OEM Honda style connectors.
Then you can splice these onto the replacement front (or rear) signals for proper installation.
post #10 of 12 (permalink) Old 06-09-2012, 01:44 AM
COBRA90GT's Avatar
Quoted: 47 Post(s)
Lightbulb
Originally Posted by dasrider View Post
...They're super expensive, but I'll never go any flushmount route unless its Watsen Design. People will know when you're turning. I had Protons on my old R1 and they were okay, but didn't grab your attention like the Watsen's do...
I too, had a similar opinion until I saw the Protons wired up to my bike firsthand - if you set them to the "strobe" feature, they are just as good, if not better than Watsens IMHO.
I ran Watsens on my old 600RR before and the Protons are plenty bright, especially at night, and provide a good level of visibility when facing the front (as if oncoming traffic were looking at you - highly important here, due to the inherent design of "flushmounts").
FWIW, I'm not even sure if Roger (of Watsen) is still offering his flushmounts for sale anymore (vaguely remember reading something about him "halting" production due to demand? Someone correct me if I'm wrong - thx).
YMMV, of course...
'06 Black/Metallic Gray RC51
-Competition Werkes FE w/
Clear Alternatives IT
'02 Silver/Black CBR 954RR
COBRA90GT is offline
