Need Help With Fuel Problem - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 4 (permalink) Old 06-24-2012, 10:09 PM Thread Starter
cantonRC's Avatar
I did a track day last Saturday and went to start my bike yesterday and it would not start. I checked and am getting spark and if I put fuel in the intakes it will run for a second. Fuel pump pumps gas I don't have a way to check the pressure but it seems to pump fine I didn't check the flow but it seems more than enough to get it to at least run.
The plugs are dry along with the air coming out of the plug hole if you turn it over without a plug in it.
How can you check the fuel pressure regulator ? And can it stop the fuel flow ? The book didn't show anything but the removal and installation.
Or what could stop all the injectors from injecting fuel all at once
Thanks,
cantonRC is offline
post #2 of 4 (permalink) Old 06-24-2012, 10:23 PM
See here for info.
https://www.rc51forums.com/forums/sho...fuel+regulator
post #3 of 4 (permalink) Old 06-25-2012, 06:57 PM Thread Starter
cantonRC's Avatar
The fuel rail had fuel in it. So it looks like the only thing left is my injectors are not firing any ideas on what would cause them not to work ?
cantonRC is offline
post #4 of 4 (permalink) Old 06-25-2012, 07:46 PM
If you haven't already, go to the link below and download the service manual (in PDF format) called "Honda_SP1_SP2_Factory_Service_Manual"
http://www.carlsalter.com/honda-service-manuals.asp
Follow the steps in checking each injector.
If each injector checks out, then the problem is elsewhere.
