For those of you... - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 7 (permalink) Old 06-26-2012, 07:41 PM Thread Starter
For those of you...
For those who have had issues with radiators or oother pieces cracking/chipping/falling_________ (insert your favorite word here), take a look at the rubber and foam pieces that are used to hold, or dampen vibration during operation. I have changed out my radiator mounts and left side radiator foam pieces. I did notice movement before this but now, not so much.
These bikes are getting some age on them and it looks like the rubber and foam bits might be reaching the end of their limits.(Mine is a 2003 with low miles and always garaged!)
Just a thought.
post #2 of 7 (permalink) Old 06-26-2012, 08:35 PM
When my SP1's radiator blew out, I ordered a brand new one (SP1 again with 2 mounts) along with all its foam pieces around it. Next think I know 8 months later, it was blown out at the exact same spot as the first one.
Then my thoughts were that, due to it's two mounts, the radiator was vibrating/twisting at a diagonal axle line that meets the two mounts. So when you are at 9000-10000rpms with your coolant at 110 deg.Celsius and 1.1 bar of pressure inside the radiator, the upper mount stretches the tube beneath it and cracks it alongside of it.
That's why I decided to drill my frame and install the SP2 radiators which have the one extra mount at the rear upper corner. I guess all we need to do is observe the HRC solving the problems and follow their steps
post #3 of 7 (permalink) Old 06-26-2012, 09:59 PM
2strokersmoker's Avatar
very interesting indeed...... I just had my plastic off tonight doing an oil change and inspection and I did take a look at the rads real close.. no leaks but yep the foam is stiff and not really doing its job... order up!
2strokersmoker is offline
post #4 of 7 (permalink) Old 06-27-2012, 04:53 PM
budoka's Avatar
Quoted: 56 Post(s)
Thanks for that mad. I'll look at mine before I put the fairings back on for sure.
'03 SP2, '09 GL1800
budoka is offline
post #5 of 7 (permalink) Old 06-29-2012, 02:37 PM
once again thanks mad i will be checking on that soon as i get a chance.
hontech is offline
post #6 of 7 (permalink) Old 06-29-2012, 04:24 PM
Good point embee. But I'm not sure that the SP1 rads were ever supposed to be solidly tight to the frame. As with the third mounting point on the SP2's. Someone here already pointed out the SP2 was a lot of correcting issues with the SP1. Such as leaking weld on the gas tank, judder spring and seat for the clutch, and the rads.
I checked the condition of the rubber mounts, which are sleeved with a spacer, specifically to prevent rigidity. Apparently. Because when I tighten the two mounting bolts, the radiator still has a small amout of flex, provided by the rubber, sleeved bushings that are part of the mounting bracketry.
So, I thought there was supposed to be some movement, and that it would be better than a rigid mount.
post #7 of 7 (permalink) Old 06-29-2012, 05:11 PM Thread Starter
There is "movement" of a newer mount and "movement" of an aged/cracked mount that has lost its elasticity. Correct, they are suppose to move but the ability of the rubber to dampen is much better when it has that elasticity
