Help! Bike runs like crap! - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 12 (permalink) Old 07-08-2012, 06:45 PM Thread Starter
cbrjames's Avatar
So I was riding to work yesterday morning and everything was just fine. Take a nice sweeping curve at high speed. After that bike start bogging down on decel, and exhaust sounds terrible and is popping. So I check for exhaust leaks and don't find any. Pull my tank up thinking maybe my tb came loose from the t1 airbox, and all is good there. What else should I check?
cbrjames is offline
post #2 of 12 (permalink) Old 07-08-2012, 07:55 PM
spark plugs ok?
cacc is offline
post #3 of 12 (permalink) Old 07-08-2012, 08:14 PM
This might be a longshot, but I've seen the insulator band screws loosen on the boots that connect the throttlebody's to the cylinder heads. Made me think it might be sucking in a little unmetered air. You need a long screwdriver orI think it's a 6mm hex head or long screwdriver, and you gotta get just the right angle. There's an upper and a lower clamp on both the boots. It's page 5-61 in the manual.
I didn't have any symptoms before I discovered that, just found it when I was doing some other stuff.
post #4 of 12 (permalink) Old 07-08-2012, 09:20 PM Thread Starter
cbrjames's Avatar
Haven't checked the plugs yet. TV boots are right on upper and lowers, I checked that yesterday.
cbrjames is offline
post #5 of 12 (permalink) Old 07-08-2012, 09:31 PM
Quoted: 37 Post(s)
do you have a PCIII? all the connections etc good with that?
gts455 is offline
post #6 of 12 (permalink) Old 07-08-2012, 10:59 PM
Since you don't get an FI indicator flashing, it probably is not some sensor so the PC III gone bad is one good guess and you should definitely check your FPR too.
How is your idle speed? Higher or lower than normal?
post #7 of 12 (permalink) Old 07-09-2012, 12:42 PM Thread Starter
cbrjames's Avatar
Would a 6 month old PC3 go bad this soon? And what's my FPR? Idle speed is normal.
cbrjames is offline
post #8 of 12 (permalink) Old 07-09-2012, 01:01 PM
It will if you didn't route the wiring carefully. Sometimes folks pinch the wiring when remounting the tank.
I'd check for a loose ground first.
post #9 of 12 (permalink) Old 07-09-2012, 01:01 PM
Quoted: 37 Post(s)
Wouldn't necessarily go "bad". one of the connections could be loose or could be grounding out. Try reloading your map onto it. Also did you have a custom tune or are you jsut using a generic map?
gts455 is offline
post #10 of 12 (permalink) Old 07-09-2012, 01:19 PM Thread Starter
cbrjames's Avatar
Wires aren't pinched. The map I'm running is one I got from someone off of here.
cbrjames is offline
