time for chain an sprockets - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 11 (permalink) Old 07-15-2012, 09:40 PM Thread Starter
Ok so the sprockets are starting to fish hook a little an im gonna replace them an the chain while im at it.. so my question is what should i get for a chain people keep saying ill snap a 520 chain with the torque of the RC51 an i do tend to accelerate hard so i dont wanna snap a chain I wanna go down 1 in the front an up 2 in the rear being thats what the bike has now an i like it So i need some suggestions also should i got steel sprockets or Aluminum
rockintwisties2011 is offline
post #2 of 11 (permalink) Old 07-15-2012, 09:49 PM
Not to worry, it won't snap a 520 chain.
The chain is what wears out the sprockets, so it's important to frequently clean, lube, and check adjustment of the chain. Regardless of type.
post #3 of 11 (permalink) Old 07-15-2012, 09:51 PM Thread Starter
i usually clean an lube the chain about every 2 weeks or after riding in the rain
post #4 of 11 (permalink) Old 07-15-2012, 09:53 PM
I have used RK 520 chains on all of the bikes I haved owned with no issues.
Sprockets...do a search, there are plenty of threads out there discussing this.
post #5 of 11 (permalink) Old 07-15-2012, 10:03 PM
I run an RK XSO 530 chain on mine, I too have had excellent success.
post #6 of 11 (permalink) Old 07-15-2012, 10:07 PM
DID here. 520 and aluminum rear sprocket. The first set was good for somewhere around 20,000 miles. I just recently replaced the whole set with the same.
post #7 of 11 (permalink) Old 07-16-2012, 01:13 AM
rc51anthony's Avatar
DID gold --520 -- driven sprockets --
  • Moriwaki rearsets
  • Power Commander USB
  • DID 520 gold chain
  • CRG folding clutch lever
  • Flapper PAIR EVAP removed
  • Soft Rev limiter removed
  • 15/41 gears 520
  • Vortex clip-ons
rc51anthony is offline
post #8 of 11 (permalink) Old 07-16-2012, 09:47 AM
screamin chief's Avatar
Driven sprockets all the way! 520 with the rk chain Sub mentioned above
Sent from my HTC PH39100 using Motorcycle.com Free App
2000 RC51
1985 ATC 350X
2009 Silverado SS clone
Lots and lots of guns!lol
screamin chief is offline
post #9 of 11 (permalink) Old 07-16-2012, 05:01 PM
Quoted: 331 Post(s)
All the info you need and then some
http://www.rc51.org/gearing.htm
post #10 of 11 (permalink) Old 07-16-2012, 05:42 PM
Kyle Racing has good 520 conversion kits for the RC51.
DID ERV3 520 pitch 120 link gold chain
steel countershaft sprockets
hard anodized aluminum rear sprockets supplied by either AFAM or Drive Systems
http://www.shop.kyleusa.com/product....&categoryId=34
cacc is offline
