bad link? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 19 (permalink) Old 07-27-2012, 08:09 PM Thread Starter
bad link?
Does anyone know what it means if your chain is tight in some areas and loose in others. I notice when I have my bike up on the rear stand and I check the chain tension, the chain seems tight sometimes and sometimes it's loose even though I havent done anything. As I move the wheel and check tension, it seems to change tension depending on the location. Does that mean I need a new chain? A stiff link?
cacc is offline
post #2 of 19 (permalink) Old 07-27-2012, 09:27 PM
how old is the chain?
mark32786 is offline
post #3 of 19 (permalink) Old 07-27-2012, 09:37 PM Thread Starter
Not sure. I got the bike in May and I havent changed it. The sprocket looks ok. I have plans to get a 520 conversion but was going to wait until winter.
cacc is offline
post #4 of 19 (permalink) Old 07-27-2012, 10:05 PM
well for what its worth i just swapped mine to 15/41 520 combo. mine had around 15k with the original chain for what i can tell. it was showing some signs of wear on the rollers and some side to side sloop on the sprocket. i paid 151.00 for a rk kit off amazon.mfg #1102049S. if you get this kit you will have to cut some links off for it to fit.i would think if you had a kink link you would see it. are your sprockets in line?
post #5 of 19 (permalink) Old 07-27-2012, 10:39 PM
With your bike on a stand, if you rotate your rear wheel while check the chain tension, if the chain has areas that are more tight than others, that usually means your chain is worn.
If the difference between tight and loose is too great, then the chain is badly worn and chain & sprocket replacement is needed.
Remember that the chain wears out the sprocket teeth. So both chain AND sprockets need to be replaced as a set, or you're wasting time and money.
post #6 of 19 (permalink) Old 07-27-2012, 11:02 PM Thread Starter
The sprocket looks ok. But I guess I might as well get the 520 kit from scotts and do it all...
cacc is offline
post #7 of 19 (permalink) Old 07-29-2012, 07:33 PM
That would be your best and safe bet. Better to KNOW your parts are good then guess about it and suffer for it in the end. 520 kits are the way to go.
Duckhunter is offline
post #8 of 19 (permalink) Old 07-29-2012, 11:19 PM
2strokersmoker's Avatar
Just a little bit of thought in a different direction..... Is there any evidence that the previous owner had a chain break? Any cracks or funky Knicks around the sprocket area? Check behind the clutch slave cover. Reason being is I had a master link fail on me awhile ago ( nope not my rc) and after I had put a new chain and sprockets on I had noticed that the chain would get tight about half way around... I found out that I bent the output shaft ever so slightly when the chain snapped and came whipping around taking everything out but the engine case thankfully.
Just something to check while your there...
2strokersmoker is offline
post #9 of 19 (permalink) Old 07-30-2012, 11:08 AM
Good point, good post.
post #10 of 19 (permalink) Old 07-30-2012, 11:56 AM Thread Starter
Thanks for the advice guys. From what I can remember, it always seems like it is the same place on the chain where this happens. I did notice that the marked lines were not the same on each side. So what I did was I marked the adjustment bolts and counted the amount of full turns it took from all the way in to where the stop was. They were different. I fixed that and the lines lined up the same on each side after that. But it didnt seem to fix the problem. I will look at it some more this week.
cacc is offline
