Engine breaks up after 7k? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 7 (permalink) Old 07-29-2017, 07:12 PM Thread Starter
Canty's Avatar
Quoted: 43 Post(s)
Hey guys, I need some advice. When I ride, I typically keep it under 5k. However, over the last few days I have had the opportunity to open it up a little bit. I noticed right away that after about 6.5-7k the motor breaks up. It still accelerates, but does not sound healthy at all. I have no F1 light, plugs and air filters are less than 500 miles, oil has just been changed. I run high octane fuel only and only on occasions will I run a fuel additive such as Gumout Regain, or Seafoam. The bike does just fine when I am just cruising so it really isn't a big deal for me and my riding style, but if something is wrong I want to address it and fix it. Any ideas where to start? What tests I can run? I have a feeling it is a air/fuel issue but I do not have the equipment to test that at that RPM.
Thanks guys.
2004 RC51
Canty is offline
post #2 of 7 (permalink) Old 07-31-2017, 01:57 PM
Quoted: 334 Post(s)
Loose battery connection probably. Put a wrench on the cable bolts and make 100% sure they are guudentight
post #3 of 7 (permalink) Old 08-01-2017, 08:38 AM
budoka's Avatar
Quoted: 56 Post(s)
My '82 750 did that when the valves were out of spec. LDH is the Gawd of RC compared to me but might not hurt to check the clearances just to be sure.
'03 SP2, '09 GL1800
budoka is offline
post #4 of 7 (permalink) Old 08-01-2017, 12:26 PM
Any after market exhaust and power commander fitted?
If so, is a good dyno tune used with the power commander?
When I bought my bike years ago, the prior owner must have never had it dyno tuned, as the engine would enter a lean state at around 5800 RPM that grew so bad it would start misfiring until 6800 RPM, ant which point it then ran great.
I had a good dyno tune done on it and it ran perfect afterwards throughout the rev range.
post #5 of 7 (permalink) Old 08-01-2017, 04:05 PM
Quoted: 330 Post(s)
Yeah could be a loose terminal, Could also be low flow from the fuel pump Among other things
Start with the easy stuff. If there is a power commander or similar, disconnect it. Check terminal connections etc
post #6 of 7 (permalink) Old 08-01-2017, 08:29 PM Thread Starter
Canty's Avatar
Quoted: 43 Post(s)
Sorry to not reply quickly...long work week.
No power commander installed currently. Still in the box waiting to be installed.
2 into 1 exhaust from previous owner installed.
All other mods done by me, just the simple ones like the flapper valve and the PAIR mod. Have not done the Soft Rev limiter.
No dyno tune since I took the bike. I am sure it would help and most likely I would find the problem while doing it, I just do not know of a dyno tune location near me.
I am pretty sure my battery cables are tight, I will check next week when I get back home. Valves looked good and sealed good when I rebuilt the motor 2 years ago (less than 1000 miles ago). However, a test to verify pressure is being held and not leaking past the valves couldn't hurt.
Fuel pump was (at time of rebuild) flowing well. I will say that pump has some issues though. Like it always reads low fuel. I doubt this has anything that could inhibit flow and fuel volume or pressure but you guys would know better than I would.
Thanks for the advice thus far. Many of you will be happy to know that I have removed the extended swing arm as you all have said I should and have put on a stock SP2 swing arm.
2004 RC51
Canty is offline
post #7 of 7 (permalink) Old 08-07-2017, 02:37 PM
What brand 2-1 exhaust is installed? Jardine?
If so, with no power commander installed, that is probably your problem.
That's the exhaust system installed when I bought my bike, and while it had a power commander installed, I doubt the prior owner ever dyno'd the bike since it was very lean starting at 5800 RPM to where it would stutter and misfire badly (not good). Once past 6200 RPM it ran fine.
After the dyno tune, no further problems. Plugs had a nice honey color on the insulators.
