Lightened Clutch Basket - Honda RC51 Forum : RC51 Motorcycle Forums
 9Likes
post #1 of 23 (permalink) Old 05-20-2018, 06:11 PM Thread Starter
Quoted: 15 Post(s)
Anyone know where I could purchase one? Know anyone that could modify the stock unit?
5.4 speedster is offline
post #2 of 23 (permalink) Old 05-20-2018, 07:24 PM
Quoted: 28 Post(s)
Why ?.....
Red Flash is offline
post #3 of 23 (permalink) Old 05-20-2018, 07:40 PM
RC-DEVIL's Avatar
Quoted: 120 Post(s)
yea, i have 8 units i am working on. I supplied Derrel's (RCCBRZ/Ogiehooker) bike. These are the former Speedcell designed units that durbahn knocked off. I have the drawings/IP etc. They are just kind of a back burner project at the moment.
The stock unit cannot be modified to reduce weight.
2004 SP2 N. Hayden
1991 Honda HawkGT
2008 XR650L
RC-DEVIL is online now
post #4 of 23 (permalink) Old 05-20-2018, 07:43 PM Thread Starter
Quoted: 15 Post(s)
I would like to purchase one of these from you.
post #5 of 23 (permalink) Old 05-20-2018, 07:46 PM
Quoted: 28 Post(s)
There's more weight easier to remove from the flywheel.
post #6 of 23 (permalink) Old 05-20-2018, 08:54 PM
Quoted: 31 Post(s)
right but then you need to run a dual Baja speedcell battery setup or you end up running out of electrical power to run the FI, ECU etc...ask me how I know...
The Baja batteries are twice the capacity of the std speedcell battery and I run 2 of them with a charging port out of the rear cuddy compartment.
What uses up most of the electricity, is warming the bike up 10 minutes in the am...takes 10-20 minutes to fully recharge them after idling/warming to get ready to ride with a full power pak.
After 140 miles of fast riding today, it only took 7-10 monutes to fully recharge the system.
Alt. kit 650 or so-elektrex in UK @ Baja speedcell batteries-500 Charging harness 125
custom undertail/battery box-made my own....Lots of work and money but it makes midrange MUCH better, that and some VP fuel.
VP fuel is the cheapest thing to get 5 extra ponies...use it 50/50 with 87 octane.
I have heard you can shave SOME weight off the stock flywheel but it isn't very much. You can also use Ti bolts on the starter gear )6) to help as well, as I did.
This lightweight alternator setup helps solves one of the biggest problems I always had with the RC-too slow revving. But then light crank, rids, pistons, coatings etc helped too.
I think the clutch basket shaves like 1100 gms ...although it turns only have the rate the crank does...I like my lightweight slipper clutch..lets you freewheel more but not completely into turns.
My 2 cents.
Name:	CLUTCH VS DURBAHN SIDE BY SIDE.jpg
ID:	127883   Click image for larger version
Name:	STATOR END (1024x576).jpg
ID:	127885   Click image for larger version
Name:	DSC01607 (1024x576).jpg
ID:	127887   Click image for larger version
ID:	127889   Click image for larger version
rccbrz is offline
post #7 of 23 (permalink) Old 05-20-2018, 09:04 PM Thread Starter
Quoted: 15 Post(s)
I'm not interested in messing with the stock charging system so no flywheel adjustments for me. Where did you source the TI bolts for the starter gear? What are you using for your slipper?
post #8 of 23 (permalink) Old 05-20-2018, 09:09 PM
Quoted: 31 Post(s)
Probolt out of the UK.....yoydyne slipper....PM me and we can talk on the phone if u like......
rccbrz is offline
post #9 of 23 (permalink) Old 05-21-2018, 12:14 PM
Quoted: 85 Post(s)
Helps with the handling too
dansp1 is online now
post #10 of 23 (permalink) Old 05-22-2018, 12:10 PM
Quoted: 4 Post(s)
My flywheel is 300 grams lighter (2200 - 1900), no problems on the road. Purchased it years ago from a guy in Portugal. Plan to take it a further step by step.
Red Flash likes this.
SP1:PVM mag.,full Akra,Durbahn airbox,T1 G2 snorkel,SpeedCell,SP2 swing+mod. subfr.+engine cover,WP susp. +TiN,endur. fairing VFR400 headlight,KYA fronts, Setrab oilcooler,MR clipons,flowed throttlebod.,lightened flywheel, Moriwaki rests, Delrin stacks,BKG triple clamps,PC II,Ti bolts, qr seat+tank,Durbahn/ISR rear brake,Durbahn CCC,AFAM 15-41, DID520,CBR600RR coils,50310 fan switch,mod. wire harness,HRC overflow,Extreme Graphics undertray,Harris fairing stay.
SPeter1 is online now
