TYGA Performance -
Racing Step Kit, VTR1000 SP2 | TYGA-Performance
There are a lot of good looking rear sets out there. Most are way to busy and clunky looking for my taste.
Plus, the majority are overpriced!
I would recommend looking at TYGA's offering. Price, quality, appearance... These guys won me over.
They are non-adjustable and as a result, look clean and slick like the original HRC factory pieces.
They moved the foot peg position up 1/2 inch (12mm) and back 3/4 inch (20mm) from stock.
I am 5'7", so this was perfect for me. The stock ones were fixed as were the HRC superbikes.
Honda thought they had it right, so why over complicate it.
The TYGA pieces work with standard or reverse pattern shift.
They do not come with a mounting point for the stock style exhaust mounts. I run Yoshimura pipes and like many, wish to still use those mounting points. I made two brackets out of 1/4 inch by 1 inch aluminum bar stock and mounted them using longer foot peg bolts.
The product is awesome! The company is awesome!
High quality. 100% CNC machined. Roller bearing pivots. Every component is replaceable.
Current price today is $219.07US. That is what they were three years ago when I bought mine.
I polished the OEM heel guards and used to retain that "factory" look.
I included a close up of the Sato's shift extender (required for reverse pattern setup), RaceTorx's shift shaft support (just a good idea), and my exhaust pipe brackets.
Also, just installed the G-Craft rear master billet reservoir and rear master return spring (no benefit in the performance department; just for curb appeal).
I do not understand why more of you have not tried these rear sets.
