supporting bike? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 13 (permalink) Old 04-06-2013, 02:12 AM Thread Starter
supporting bike?
i just got finished doing a lot of surfing on the topic and didnt really find what i was looking for. right now i have the bike resting on a tire and dont really like it. i have a swing arm stand to support the rear, but how should i support the front? i have no rafters to hang from, and no lower triple to lift either. will the oil pan or some other part of the frame/motor be used? the manual tells you how to remove the swing arm, but i didnt see anything on supplemental support. Thanks.
nykuryu is offline
post #2 of 13 (permalink) Old 04-06-2013, 02:36 AM
A couple of ways I do it; if you have crash bungs and a set of peg stands under these it will keep the bike upright or if no crash bungs then the peg stands with a bar under the front cylinder exhaust outlet will work. Even two step ladders with a bar accross and a ratchet strap under the headstock will work.
n1xxl is offline
post #3 of 13 (permalink) Old 04-06-2013, 02:39 AM
I posted a thread awhile back hole this helps...
https://www.rc51forums.com/forums/showthread.php?t=10073
post #4 of 13 (permalink) Old 04-06-2013, 02:46 AM
[/QUOTE]I have my bike right now no front end, on the side stand, jack under the motor, rear wheel jammed against the wheel chock and strapped down.
Solid no movement what so ever been that way for a few weeks...
post #5 of 13 (permalink) Old 04-06-2013, 02:51 AM Thread Starter
[/QUOTE]
what part of the motor is resting on the jack? the sump? i might go out and buy some ladders, but if i can just use my jack/stands ill use those first.
nykuryu is offline
post #6 of 13 (permalink) Old 04-06-2013, 02:54 AM
Yes under the sump...use a short piece of 2x4 to help support under the sump.
post #7 of 13 (permalink) Old 04-06-2013, 02:58 AM
I've used this method by pushing the rear wheel against a wall, on the side stand and a jack...the trick is you need to be able to strap the bike down.
At my old place I drilled into the floor of the garage and used anchors in the ground...dead solid. But use good anchors.
post #8 of 13 (permalink) Old 04-06-2013, 03:01 AM
On a different note...did you still want my clutch master cylinder/lever?
post #9 of 13 (permalink) Old 04-06-2013, 03:04 AM Thread Starter
yes, im just waiting til the corps decides to reimburse me. quick to take money, but slow as shit to give it back. ya i dont think ill be able to strap it down. ill be moving into a new house without a garage and im trying to come up with ways to suspend the bike inside a spare room or something
nykuryu is offline
post #10 of 13 (permalink) Old 04-06-2013, 03:07 AM
No worries let me know and good luck, let us know how you make out...
