2000 SP1 Hot idling problem - Honda RC51 Forum : RC51 Motorcycle Forums
  • 1 Post By jondog9
post #1 of 3 (permalink) Old 10-06-2013, 07:20 AM Thread Starter
Hi, I hope this is appropriate to post here.
I am having problem with idling when hot.
When its cold, it runs no problem, but after warm up, it just dies.
Runs okay but every time I stop, and RPM goes down, then it dies.
I suspected the clogged injectors and used a cleaner but did not make difference.
I have PCIII and Yamamoto 2:1 system on.
Any suggestions what to look for?
thanks
99' RS125 - 2008-
94' SRV250 - 2012 For Sale
81' CB250RSZR - 1981-
02' D-Tracker - Just bought!
82' CB450T- 2010-2011
94' CBR600F2 - 2008-2009
01' 900SS - 2011-2012
82' CB900FC - 2010-
03' RVT1000SP2 - 2009-2011
00' RVT1000SP1 - Importing
rc301990 is offline
post #2 of 3 (permalink) Old 10-06-2013, 12:32 PM
Quoted: 312 Post(s)
My first guess is the fuel pressure regulator.
Has the bike been sitting for a little while?
The fpr's are a common failure.
You can test them, but occasionally they appear to pass the test and they still cause problems. Like your's.
Lift the tank, pull the small vacuum hose off the fpr, then turn your key on to prime the fuel pump. watch for leaking gas from that small nipple for the vacuum line you just pulled.
Trace likes this.
jondog9 is online now
post #3 of 3 (permalink) Old 10-06-2013, 01:03 PM
screamin chief's Avatar
Its worth changing tge fpr regardless of the problem. Mine seemed like a electrical problem and disappeared when I changed the fpr
2000 RC51
1985 ATC 350X
2009 Silverado SS clone
Lots and lots of guns!lol
screamin chief is offline
