2003 RC51 Suspension sag rate - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 8 (permalink) Old 04-22-2010, 01:34 PM Thread Starter
Does anyone know the suspension sag rate for a 2003 RC51. Need to set is up but don't know what to set the sage at for a 17lb rider. Does anyone know?
hammerlock is offline
post #2 of 8 (permalink) Old 04-22-2010, 09:33 PM
Roughly speaking,
At the rear:
Static sag: 5-10mm
Rider sag: 30-35mm
At the front:
Static sag: 10-15mm
Rider sag: 30-38mm
post #3 of 8 (permalink) Old 04-23-2010, 07:46 AM
Does anyone know what the stock suspension was set up for from the factory (rider weight)?
I checked out the sport rider guide for suspension set up and it lists different settings for different years, but I thought this bikes suspension was the same for all years?
hdeez is offline
post #4 of 8 (permalink) Old 04-23-2010, 07:59 AM Thread Starter
post #5 of 8 (permalink) Old 04-23-2010, 05:49 PM
The '02-'06 OEM base settings for stock suspension are:
Front preload: 6 turns CW from full soft (CCW)
Compression: 12 clicks CCW from full hard (CW).
Rebound: 1 turn CCW from from full hard (CW). Should have punch marks aligned.
Rear preload: Ramp 5 from full soft (ramp 1).
Compression: 10 clicks CCW from full hard (CW).
Rebound: 1 turn CCW from full hard (CW). Should have punch marks aligned.
LIGHTLY turn the rebound adjusters to the full hard stop or risk damaging the adjuster.
post #6 of 8 (permalink) Old 04-29-2010, 11:42 AM
i dont think the bike will allow you to set the sag for a 17lb rider. front sag should be set to approx 35-40mm's, and rear at 25-30mm's depending on the type of riding you do.
bmfgsxr is offline
post #7 of 8 (permalink) Old 04-30-2010, 01:48 PM
so.... CW? Or (CCW)? I'm confused.
-Tony B
00 RC51
06 Evo IX
Ev0lv3d is offline
post #8 of 8 (permalink) Old 06-01-2010, 09:23 PM
atvrcr500's Avatar
Quoted: 11 Post(s)
CW = Clock Wise
CCW = Counter Clock Wise
2004 RC51 with multipul mods
1985 VF1000R SOLD 😭
atvrcr500 is offline
