Reset tilt sensor? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 4 (permalink) Old 03-13-2008, 04:27 PM Thread Starter
Reset tilt sensor?
I need to know if anyone can walk me through how to reset the tilt sensor on my RC51; i high-sided, slid the bike about 100 feet and can't get the engine to turn over. Coil, fuse, plugs and fuel line are all good, fuel pump turns on with ignition, but no fuel or spark.
scoob is offline
post #2 of 4 (permalink) Old 08-14-2008, 10:03 AM
Deals Gap Dragon Slayer's Avatar
on most bikes with a tilt sensor, you have to hit the kill switch to the off position, then back on... then turn the keey off, then back on... and it should start up
Damien
2002 Honda RC51
2007 Kawi ZX-10R
If you see my bike on a trailer, it broke down, someone stole it, or you should follow me to the track
Deals Gap Dragon Slayer is offline
post #3 of 4 (permalink) Old 06-21-2016, 10:27 AM
Any idears would a tilt sensor still let the bike crank but not start. Bike primes cranks just won't start. I put u deepest on and all wires ecu were a pain get back on. I checked everything I cannot see why it won't start. It started fine a week ago. It has a new battery power commander was already on it Would tilt sensor cause this ? Or have I disturbed a cable. Everything is how it should no f1 lights primes fuel pump cranks but nothing thanks
Big pete is offline
post #4 of 4 (permalink) Old 06-21-2016, 10:39 AM
AMP1's Avatar
Quoted: 27 Post(s)
do you mean you road rashes for 100 feet??
check grounds most at right side frame near seat front
AMP1 is offline
