fluid comes out of motor , is it ok and what is it ?? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 22 (permalink) Old 08-11-2011, 06:42 PM Thread Starter
rc51anthony's Avatar
on the right side of motor where red arrow is pointing fluid comes out when im riding or when motor is running , is this ok and should i just cap it to drain later
  • Moriwaki rearsets
  • Power Commander USB
  • DID 520 gold chain
  • CRG folding clutch lever
  • Flapper PAIR EVAP removed
  • Soft Rev limiter removed
  • 15/41 gears 520
  • Vortex clip-ons
rc51anthony is offline
post #2 of 22 (permalink) Old 08-11-2011, 06:52 PM
What kind of fluid? Coolant, oil? And pics are kinda small, where you pointing to the vent tube or the radiator hose clamp?
firstcherokeekid is offline
post #3 of 22 (permalink) Old 08-11-2011, 06:59 PM Thread Starter
the vent tube , clear tube , not oil , i dont think its antifreeze because its not green , i think its water there is no smell . more like a dirty water hard to explain
  • Moriwaki rearsets
  • 15/41 gears 520
  • Vortex clip-ons
post #4 of 22 (permalink) Old 08-11-2011, 07:05 PM
Its fine. Don't worry about it and keep riding. Just every month or so empty the tube, depending out how much collects there.
post #5 of 22 (permalink) Old 08-11-2011, 07:08 PM Thread Starter
ok what is it from ? and what if i dont drain it in time and it fills up to the top , just if ? i will drain before every ride thanks .
  • Moriwaki rearsets
  • 15/41 gears 520
  • Vortex clip-ons
post #6 of 22 (permalink) Old 08-11-2011, 08:20 PM
That is the water pump inspection hose (aka the water pump mechanical seal bypass).
It's dripping coolant onto the ground because the mechanical seal in the water pump is shot, and coolant is leaking past the seal.
You have two choices: 1) Repair the existing water pump by replacing the mechanical seal, or 2) replace the entire water pump.
If you don't, the seal will eventually completely fail, and all your coolant will drain out.
http://www.mrcycles.com/fiche_sectio...2002&fveh=3621
post #7 of 22 (permalink) Old 08-11-2011, 08:21 PM
Those are vent tubes that are capped with the rest of the overflow/vent tubes. They usually have residual oil in them.
post #8 of 22 (permalink) Old 08-11-2011, 08:24 PM Thread Starter
wait its the clear tube , the little one , is this right what you say ,
  • Moriwaki rearsets
  • 15/41 gears 520
  • Vortex clip-ons
post #9 of 22 (permalink) Old 08-11-2011, 08:25 PM Thread Starter
so you say its ok , i just have to drain it , ??? who is right , ahhhh
  • Moriwaki rearsets
  • 15/41 gears 520
  • Vortex clip-ons
post #10 of 22 (permalink) Old 08-11-2011, 08:39 PM
Is this where the hose attaches?
