whats wrong , gas tank got a dent in it , could be bad gas cap - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 4 (permalink) Old 10-17-2011, 03:14 PM Thread Starter
rc51anthony's Avatar
  • Moriwaki rearsets
  • Power Commander USB
  • DID 520 gold chain
  • CRG folding clutch lever
  • Flapper PAIR EVAP removed
  • Soft Rev limiter removed
  • 15/41 gears 520
  • Vortex clip-ons
rc51anthony is offline
post #2 of 4 (permalink) Old 10-17-2011, 04:38 PM
cbrbear's Avatar
yes tank not venting, normally they shut off before they do that to the tank. you need to clear out the vent line, you can remove the tank, blow some air through it and see if it comes out...
cbrbear is offline
post #3 of 4 (permalink) Old 10-17-2011, 09:46 PM
cbrbear's Avatar
it probably cleared itsself when it sucked in the tank....
cbrbear is offline
post #4 of 4 (permalink) Old 10-18-2011, 10:08 AM
If the vent is clear, how could the cap have any effect? I don't even understand your reasoning. I'm sure it's legit, I just don't follow your train of thought on this.
