sp2 triple tweaked - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 15 (permalink) Old 11-22-2011, 10:09 AM Thread Starter
sp2 triple tweaked
im not sure whats twisted or tweaked on the front end. while riding in straight line.the triple is slighty off center to the right side.it doesnt seem to pull.i can rotate axle freely with it on stand.and pinch bolts loose. i turned the fork tubes 180 degress.didnt make a differnce.not sure what to check or replace yet
bls77red is offline
post #2 of 15 (permalink) Old 11-22-2011, 12:28 PM
You could put the bike on a front stand, then loosen the top pinch bolts and top triple tree nut to see if top triple tree then realigns.
Then re-torque the nut and bolts.
post #3 of 15 (permalink) Old 11-27-2011, 01:24 PM
My top clamp is off too, also to the right. The bike as been down on the right side. I've been over the service manual and I can't tell if there is an alignment pin or something for the top and bottom clamp.
Is there?
James
post #4 of 15 (permalink) Old 11-27-2011, 02:48 PM
Ponch 7M4's Avatar
Is there?
James
I thought I noticed mine being a little off to the right the other day when I was riding, too. It was only the third time I'd ridden the bike and I didn't notice it the first two. I just went down to the garage to take a look at it. One thing to note is that the ignition box and the little round thing under the dash may not be exactly square so if you're using that as a gauge it could make it look like the top clamp is off. I'll have to do more investigating next time I ride.
-Todd
05 RC51
08 CBR 1000 (sold)
Ponch 7M4 is offline
post #5 of 15 (permalink) Old 11-27-2011, 02:55 PM
I'm gauging mine by looking at the top clamp and the frame while riding "strait" down the road. By the key block its a good 1/2" off center.
It don't feel like its dog tracking or anything. None of the guys I ride with has enough mechanical iq to even know what "dog tracking" is, So I'm alone on that one.
post #6 of 15 (permalink) Old 11-27-2011, 03:47 PM
Is there?
James
There's no alignment pin.
Only the top nut torque secures the top triple clamp down onto the stem.
post #7 of 15 (permalink) Old 11-27-2011, 03:53 PM
Thanks Sub, guess I need to get out and try to realign everything and hope nothing is bent
James
post #8 of 15 (permalink) Old 11-27-2011, 04:12 PM
James
That nut that secures the top clamp is held by some hefty torque.
76 ft/lbs on SP1, and 101 ft/lbs on SP2.
Remember, I'm not referring to the nuts that secure the steering stem to the steering head. You should not need to touch them.
The fork pinch bolts (both upper and lower triple clamp) are secured at 20 ft/lbs.
post #9 of 15 (permalink) Old 12-01-2011, 12:09 AM Thread Starter
i haven't yet tried to loosen my upper tree .sounds like the next thing to try.hope it makes a difference.its slightly off center. anyone know what size the nut that secures the top clamp is?i have my stay loose. and the biggest socket i have is a 36mm.
bls77red is offline
post #10 of 15 (permalink) Old 12-01-2011, 10:46 AM
Do you have a Scotts Steering Damper installed? That nut is a 41mm.
