FI Light came on after soft rev limiter mod - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 5 (permalink) Old 02-29-2012, 02:48 AM Thread Starter
What's up guys .I have a 2003 RC and I just did the soft rev mod and added a gear indicator ( GIpro from Healtech )now my FI light comes on ,she backfires-then the light goes out. I only took it around the block a few times. When I jumpered the green plug under the seat to check for error codes I just get a steady FI light on...no flashes. I can not find my service manual ,what does steady light mean? Anybody have this trouble with soft rev mod?
motojo5 is offline
post #2 of 5 (permalink) Old 02-29-2012, 03:32 AM Thread Starter
I found the manual . Light staying on means no ECM problems so probably not soft rev mod issue? Right?
motojo5 is offline
post #3 of 5 (permalink) Old 02-29-2012, 08:15 PM
Not sure....did you check where you connected the kit into the ECU plug?
If thats all the work you did, then it has to be something crossed up.
post #4 of 5 (permalink) Old 03-01-2012, 12:53 AM Thread Starter
Yep. double,triple checked. I was wondering if being super low on gas would trigger FI light and exhaust popping? Seem that would be odd but I will fill it up and test after rain stops.
motojo5 is offline
post #5 of 5 (permalink) Old 03-01-2012, 05:53 PM Thread Starter
Filled tank up and took out for a ride- no popping no FI light. I am guess such a low fuel level caused the problem and the soft rev limiter mod was just coincedence. Thanks Madbuyer for helping out.
motojo5 is offline
