How to remove clutch basket or best method to clean out alot of clutch debris? - Honda RC51 Forum : RC51 Motorcycle Forums
  • 1 Post By Wibbly
post #1 of 9 (permalink) Old 04-15-2012, 06:28 PM Thread Starter
twvette's Avatar
My clutch is smoked. Can't really complain as it in a vehicle that is used in the sand with paddle tires, more than 2x the weight, and geared to really go through the gears frequently.
Got it apart to the clutch basket and noticed the basket is just caked with clutch material. Started cleaning but stopped as seemed better idea to remove basket and clean it better and not risk dropping gunk in the oil pan.
How does the large center nut come off ... what do they mean by unstaking it? What size is that nut (~30mm) and just use a 12 point socket or is it a special nut? Is there a way to hold the center of the clutch or does it really require the special tool/how easy will it come off without these tools?
Thanks ... just wanna know what I am against from here to get iff off or if I should just slowly clean the gunk out without removing the basket (any tips?)
Thanks!
Polaris RZR with an '04 SP2 transplanted in it. Chain driven through a gear box with axles and CVs. The only thing left stock on the RZR is the frame and plastics . But, the frame is beef'd up too .
twvette is offline
post #2 of 9 (permalink) Old 04-15-2012, 07:39 PM
After removing clutch basket, rinse with petrol liberally, allow to dry, new oil & reassemble.
post #3 of 9 (permalink) Old 04-16-2012, 01:56 AM
cbrbear's Avatar
you can buy the EBC clutch removal tool on ebay for 20 bucks, I have one im in SD.
cbrbear is offline
post #4 of 9 (permalink) Old 04-16-2012, 10:34 PM
Staking is method to secure two parts together, like a nut and bolt, or bolt threaded through a threaded hole.
For instance, a bolt passed through a spacer with a nut securing it on the other end.
A staking punch is used on the center of the bolt to deform or flare the bolt's out diameter enough to prevent the nut from fully rotating off the end if it becomes loosened, which it shouldn't if staked properly.
post #5 of 9 (permalink) Old 04-18-2012, 05:01 PM
Thanks for that SubSailor. Excellent description. Another piece of knowledge in my repertoire.
post #6 of 9 (permalink) Old 08-29-2017, 03:37 AM
Dutchy's Avatar
Resurrecting...
Does one need the EBC tool to "lock" the vasket or is it as simpel as putting the bike in gear (as some suggest)?
Dutchy is offline
post #7 of 9 (permalink) Old 08-29-2017, 10:54 AM
Quoted: 326 Post(s)
if you put the bike in 6th gear and have someone on the bike holding the brake (or better yet the bike on the ground holding both brakes) it's not going to go anywhere.
the clutch holding tool makes it much easier for one person to do the job himself.
Wibbly is offline
post #8 of 9 (permalink) Old 08-29-2017, 11:36 AM
Dutchy's Avatar
Cheers for that Wibbly!
(Factory pro evo star kit ordered for something to do over the winter :-) )
Dutchy is offline
post #9 of 9 (permalink) Old 08-29-2017, 12:06 PM
Quoted: 326 Post(s)
a word of warning for when you do the job.
you'll have to take off the large cover (not just the small clutch cover) to get proper access. so you need to drain the coolant
you'll also need to pull the clutch basket. the basket itself drives the oil pump, so it's CRITICALLY IMPORTANT that when you put the clutch basket back on, you rotate the oil pump gear until the pins on the drive wheel for the pump fall into the pockets on the back of the basket. if you fuck this up you may end up with an engine failure.
the rest is very easy.
LDH® likes this.
Wibbly is offline
