04 Wont start while on sidestand - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 8 (permalink) Old 06-05-2009, 07:34 AM Thread Starter
DRFLGD's Avatar
I am looking at an 04. The bike will not start while on its sidestand. Crazy. I dont remember my 01 doing that. Possible problems? Bike is clean and never been down. Bike rode like a dream. But when I stopped to take some pics (while on a test ride) I put the sidestand down and it kept running. As soon as I leaned it over and the sidestand had weight on it, it quits running.
Thanks for any input
Marc
DRFLGD is offline
post #2 of 8 (permalink) Old 06-05-2009, 11:25 AM
So your bike runs with the sidestand down, but stops when the bike's weight is applied onto the stand?
I'd check your sidestand switch. Then same bolt holds the sidestand and the switch.
You can pull the connector behind the left side cowl and use a continuity meter to check the operation.
Also check the clutch switch as well.
The clutch switch, sidestand switch, and neutral indicator switch work together for the engine cutoff safety circuit.
post #3 of 8 (permalink) Old 06-05-2009, 02:25 PM
yup, first place to look is that sidestand switch
finepooch is offline
post #4 of 8 (permalink) Old 06-05-2009, 03:06 PM
I concur
Cam-06RR is offline
post #5 of 8 (permalink) Old 06-05-2009, 03:54 PM
i forgot: good luck sorting your issue out
post #6 of 8 (permalink) Old 06-05-2009, 04:13 PM Thread Starter
DRFLGD's Avatar
Yep bike runs fine unless the weight is on the sidestand. Also, the fuel pump will not prime while on the sidestand. But take the weight off and I can hear the fuel pump prime and it will start.
DRFLGD is offline
post #7 of 8 (permalink) Old 06-18-2009, 10:09 AM Thread Starter
DRFLGD's Avatar
Ok. I got the RC. I felt the wires from the sidestand switch and they are broken where they round the frame. I will order a new switch today and rock on!
Thanks everyone!
DRFLGD is offline
post #8 of 8 (permalink) Old 06-24-2009, 07:37 AM Thread Starter
DRFLGD's Avatar
Ok. Went to put switch on last night! Fackin bike did the same thing. LOL. So my wife and I started lookin at the PCIII and its connections to see if there was a chaffed wire. That was fine. Then I noticed the lean angle sensor (I'm guessing) was only bolted on with one bolt. So I put it back where it should be turned key and it primed every time. So I bolted it down. PROBLEM FIXED
DRFLGD is offline
