cam pulse generator - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 9 (permalink) Old 07-22-2013, 09:01 PM Thread Starter
cam pulse generator
Is the cam pulse generator basically like a crank position sensor - as far as the info it sends to the ECM?
post #2 of 9 (permalink) Old 07-22-2013, 11:01 PM
Yes and it distinguishes firing on front or rear cylinder for the ECM with an asymmetrical firing gap on the rotating part attached to the cam.
post #3 of 9 (permalink) Old 07-23-2013, 01:29 AM Thread Starter
Thanks Makis, I was trying to figure out the difference between the cam pulse generator and the ignition pulse generator. Because we use the term pulse generator when we've talked about code 19.
post #4 of 9 (permalink) Old 07-23-2013, 02:52 AM
They are both pulse generators.
They read the pulse, that is generated, with the exact same way:
a coil is triggered by the movement of magnetic stream flow inside the iron core it is twisted around of and a low voltage instant current is flowing through that coil which is picked up by the ECU.
So you should name the fault indication by the sensor's name.
post #5 of 9 (permalink) Old 07-23-2013, 10:35 AM Thread Starter
Right.
18 is the Cam pulse generator and 19 is the Ignition pulse generator.
I've seen a few code 19 issues discussed here, but I haven't seen any code 18 issues yet. Anyway, both of them are pretty straight forward diagnosis.
post #6 of 9 (permalink) Old 06-02-2016, 04:15 PM
Still confused
Hi, old thread but its what im trying to figure out.
It dont make sense to me lol
Sooooo
Cam pulse generator is responsible for timing of ????
Ignition pulse generator is responsible for timing of ??????
Short answers welcome
Long answers even more welcome
The more i find out, the less i know :-)
Thanks
boredcol is offline
post #7 of 9 (permalink) Old 06-02-2016, 09:57 PM
Since it's a 4-stroke engine, the flywheel will make 2 complete rotations per cycle.
As a DOHC system. The cams make one revolution per cycle.
Therefore, the flywheel pulse generators will have two sets of pulses while the cam pulse generator will have one.
Therefore, the ECU will know the crank/piston is at proper timing and using the cam pulse timing to trigger spark firing for each cylinder.
post #8 of 9 (permalink) Old 06-03-2016, 10:08 AM
Okay
I think i have it
So they are basically working together to establish correct firing/sequence.
boredcol is offline
post #9 of 9 (permalink) Old 06-03-2016, 03:45 PM
Originally Posted by boredcol View Post
Okay
I think i have it
That's correct.
