Anyone knows what the problem to my con rod & cylinder head - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 3 (permalink) Old 08-08-2010, 08:21 AM Thread Starter
mighty max's Avatar
Found out there is a skid marks in the cylinder head & con rod..
Can anyone knows the problem & how to prevent it as i wanted to changed to JE piston...
ID:	668   Click image for larger version
1/6 HRC Fast Trottle,Scorpion SS Slipon Race Can,15/42(530) Afam Sprocket,PC3 WZ Yoshi Mapp,Brembo RCS Master Pump,After Market Brake Line, Flapper Valve Mod,Pair Removal Mod,Rumble Under Tray,RockWall Clipon,Endurance Race Fairing,
Hyper Pro 3D Shock,Turnone Kevlar Airbox & Carbon Intake, Hyper Pro Height Raiser Kit,Hyper Pro Linear Fork Spring,Harris Rear Set, CF Stator & Clutch Cover..more to come..., Slipper Clutch,Radiator Scoop,Factory Pro Shift Kit,
mighty max is offline
post #2 of 3 (permalink) Old 08-08-2010, 08:28 AM Thread Starter
mighty max's Avatar
here is the picture of the con rod
ID:	670   Click image for larger version
post #3 of 3 (permalink) Old 08-08-2010, 03:03 PM
Max, sorry man, but those photos were too small and out of focus to tell anything about the problems.
Try using the close up object setting on your camera at higher resolution.
