Boring - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 6 (permalink) Old 10-07-2010, 02:04 AM Thread Starter
Boring
Relatively new to the motorcycle world, but I picked up a clean 2001 frame and an engine that needs work for cheap. I'm familiar with automobile engines, but I have some questions about the v-twin.
The original owner ran it on a bad water pump and it scored the cylinders and it needs to be bored out. One of my main questions is; what are the standard overbore specifications and where is the best place to find overbore pistons and rings?
I will definitely have more questions later and will need almost everything for the bike, so if anyone happens to have a parts bike sitting around I would be more than happy to take it off your hands.
Thanks
Brandyn
Brandyn is offline
post #2 of 6 (permalink) Old 10-07-2010, 08:41 AM
Site Sponsor
RC51parts.com's Avatar
2mm and JE or other aftermarket pistons. There are lots of threads out there about engine rebuilds with good gains for a relatively stock motor.
RC51parts.com is offline
post #3 of 6 (permalink) Old 10-07-2010, 03:40 PM
The two OEM overbore piston and ring sizes are .25mm and .050mm overbore.
The cylinders must be bored for piston to cylinder clearance of .015 - .055mm.
Anything beyond .50mm overbore and the cylinders will either need to be replaced.
It may be possible to send them Millenium Technologies and have them re-plated if not too badly damaged.
post #4 of 6 (permalink) Old 10-07-2010, 04:03 PM Thread Starter
So I could use the standard bore pistons with oversize rings as long as it has the correct clearance?
I haven't talked to my "local" parts supplier yet but I'm having a little difficulty finding oversize pistons.
Brandyn is offline
post #5 of 6 (permalink) Old 10-07-2010, 04:09 PM
No. when you bore the cylinders to the next overbore size, the piston and rings must match.
Both pistons and rings are available in .25mm and .50mm sizes.
The cylinders must be bored slightly larger to allow for the specified piston/ring to cylinder clearance.
post #6 of 6 (permalink) Old 10-07-2010, 05:25 PM Thread Starter
Ok, you had me confused for a second there.
Brandyn is offline
