Difficulty starting when engine is warm - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 3 (permalink) Old 10-31-2010, 01:29 PM Thread Starter
I have a 2000 RC51 I just bought about 2 months ago. Fairly stock except for a change in gearing and a power commander. It started and ran amazing up until about 3 weeks ago. Then it would start no prob when cold, but was difficult to start when the engine was warm. I have to mess with the throttle now and I'm not sure why.
Took it to a dealer and apparently it needed to be tuned up. Figured that was correct since the bike sat for 1.5 yrs. before I bought it. They drained the fuel and added additive, changed the plugs, cleaned out the airbox and put in new air filters.
Left the dealer yesterday and stopped a 1/4 mile down the road to top off the gas and the bike was still difficult to start. Like I said, never had to mess with the throttle when starting and now I do.
Any ideas?
2000 RC51
CJMJ is offline
post #2 of 3 (permalink) Old 03-06-2011, 07:14 PM
too rich to start
Hot starting big singles and twins is problematic if the mixture is rich.
One possibility is your map is messed up, try reloading it if you didn't have the problem before. Check the PC ground as well, it is known to cause problems and even destroy PCs.
What is your temp reading when you are having the problem? The hotter the engine is the leaner the mixture needs to be. One thing to check is your temp sensor wire/connections.
Most maps give it a richer curve in the bottom. By fiddling with the throttle while starting you are risking fouling plugs. By holding steady at slightly off idle you are allowing more air to go through, which helps starting with a rich mixture. You may want to edit the map manually if you can and lean out the bottom at 0 - 10% throttle. It will save you some gas.
WHat is the idle once the bike starts? If it is too low this may be your problem, adjust it up a little bit.
It is an old thread but it is good to have some reference for those who may experience similar problems. Cold starting problems --> too lean, hot starting --> too rich.
Any ideas?
ZeroGara is offline
post #3 of 3 (permalink) Old 03-15-2011, 02:27 AM
rocket's Avatar
Sounds like it could be your battery, as I had this happen 2 years ago.
Lean it over a bit more and twist it. Niiice.
rocket is offline
