Need serious help - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 42 (permalink) Old 01-29-2011, 07:41 PM Thread Starter
Need serious help
Alright guys so i tackled the job of changing my stator on my rc today and put new sprockets and a chain on it. Now i cannot get the bike to start what so ever, just cranks, and cranks, and cranks. Also i cannot get the damn hydro clutch to bleed and get any pressure what so ever too it. Can anyone help me...Im totally freaking out because of these problems, bad weather or not outside, i dont like knowing there is something wrong with my toys.
Thanks in advance,
Bryan
RingB21 is offline
post #2 of 42 (permalink) Old 01-29-2011, 07:51 PM
Re-check your connections (just trust me here) When the key is turned, do you hear the fuel pump?
As for the clutch, its a bitch due to the resevoir being so small, this is where a "Mighty Vac" would help. Or, patiently pump and refill the resevoir.
post #3 of 42 (permalink) Old 01-29-2011, 07:56 PM Thread Starter
yes fuel pump kicks on. but after cranking for a few seconds the FI light flashes for a few?? What connections, all that was disconnected was the stator?
Could I have gotten it out of time or anything by pulling that side cover off?
RingB21 is offline
post #4 of 42 (permalink) Old 01-29-2011, 08:54 PM
No...its gear driven.
How many times doe the FI light flash?
post #5 of 42 (permalink) Old 01-29-2011, 08:57 PM Thread Starter
if i counted right it appeared to be 9 times???
RingB21 is offline
post #6 of 42 (permalink) Old 01-29-2011, 08:59 PM
Make sure the air intake sensor is connected to your air box. AIT That is the code for 9 blinks.
post #7 of 42 (permalink) Old 01-29-2011, 09:14 PM Thread Starter
Is that the 1 right under the gas tank on top? If so it is still good and plugged in. I checked the blinks again to make sure. And there is like a solid FI light and then it blinks 9 more times so not sure if thats counted as 10?? Thanks for the help madbuyer if it would be easier u can text me, if that works for u rather than posting on here?Ill pM u my number...
RingB21 is offline
post #8 of 42 (permalink) Old 01-30-2011, 01:14 AM
Since your pulled alternator cover, also check your pulse generator connection.
That's where your ignition signal is coming from.
post #9 of 42 (permalink) Old 01-30-2011, 09:00 AM Thread Starter
subsailor since i am getting my FI blinks, I am getting 9 or 19 which is the IAT sensor or the IPG sensor? Is there any way to go about checking these? Where does the IPG sensor run from the alternator cover and go to? I bought a ricks stator off ebay, and i think it is also bad, because I am getting the same reading I was getting from the one that I took out. When i ground 1 side and check the resistance of the prongs I get nothing what so ever which is exactly what my old 1 does?
RingB21 is offline
post #10 of 42 (permalink) Old 01-30-2011, 09:50 AM
What is the reading on the pulse generator? Is is open or closed?? The manual has nothing on the pulse generator sensor I see to trouble shoot with. If its bad, then you may have two good stators. Make sense
