new engine... not starting - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 8 (permalink) Old 03-22-2011, 07:30 PM Thread Starter
screamin chief's Avatar
hey guys need some help i have replaced my engine and took my time, made sure everything was plugged back in etc. the damn thing will not start. one thing is when i dropped the old motor, i forgot to remove the front spark plug wire it ripped out of the boot. i just screwed it back in but it doesnt sound like its getting spark. def has compression
2000 RC51
1985 ATC 350X
2009 Silverado SS clone
Lots and lots of guns!lol
screamin chief is offline
post #2 of 8 (permalink) Old 03-22-2011, 07:36 PM Thread Starter
i can also smell fuel out of the exhaust so im assuming its not fuel related
2000 RC51
1985 ATC 350X
post #3 of 8 (permalink) Old 03-22-2011, 07:41 PM
Ok. You smell fuel, so I'm guessing the fuel pump primes properly?
Does the tach cycle when the key is switched on, indicating the ECU is alive and passing it's self-test?
And does it show an FI code for a possible problem with a sensor/component connection?
Have you pulled a plug, grounded it and checked for presence of a spark? It may be electrical/ignition related.
post #4 of 8 (permalink) Old 03-22-2011, 08:09 PM Thread Starter
the tach does cycle.
no fi code.
have not pulled a plug yet but it does seem like its not getting spark
everything seems right but not starting. did you read wher i said that i yanked the wire out of the boot? dont you just need to rethread it if that happens? they are new plugs also but are the recomended ones out of the manual
2000 RC51
1985 ATC 350X
post #5 of 8 (permalink) Old 03-22-2011, 09:26 PM Thread Starter
ok its started. i remembered when i took the left radiater off, there were 2 red connections in the harness that look the same. 1 of the connections were not plugged in when i got there. so i unplugged both and swapped one set and left the other unplugged it instantly fired up. what are those connections and why would one not be plugged in?
2000 RC51
1985 ATC 350X
post #6 of 8 (permalink) Old 03-22-2011, 09:43 PM
The set of red connectors is from the pulse generator behind the alternator cover.
That was your culprit. No signal to the converter unit to create the spark.
Are you running a PCIIIr? Because the PCIIIr has a set of connectors that interconnect between the pulse generator and ECU.
It will run without them, but they were there in order to tweak ignition timing.
post #7 of 8 (permalink) Old 03-22-2011, 09:53 PM Thread Starter
i am running a pcIIIr! damn your good. ok now you should know that it has never lit up. i have seen them on youtube lit up in green. mine will not at anytime. i didnt see any other connection so should i leave the 1 set diconnected? one of the wires loops to the other?
2000 RC51
1985 ATC 350X
post #8 of 8 (permalink) Old 03-22-2011, 10:08 PM
Yep. The pulse generator connector loops through the Power Commander and back to the other pulse generator connector.
Kind of how the ECU connector does on it's way to Power Commander and on to the injector harness connector.
It obviously won't hurt to run without them disconnected.
No one tweaked the timing anyways I've heard of.
That's why I removed my PCIIIr and replaced it with a PCIIIUSB.
One less set of connections to potentially cause problems, and one Power Commander that is much easily accessed by computer.
Also make sure your Power Commander negative lead is securely fastened to the negative battery post and not some frame ground.
