throttle body question - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 18 (permalink) Old 04-21-2011, 05:33 PM Thread Starter
my friend has a 2001 rc51 an was wondering if its possible to swap to the 02 an up bigger throttle bodies an what all would be needed
rockintwisties2011 is offline
post #2 of 18 (permalink) Old 04-21-2011, 06:09 PM
You would have to tune your butt off. The '02 and up have a 12 stream injector throwing gas down the intake....
The smaller intake will need to be ported to help with the added gas. That is a tricky tune by mapping alone.
Your trying to replace a urinal with a toilet bowl....
If you are up for it, Hord racing offers port and polish jobs. ~$850 buck.
post #3 of 18 (permalink) Old 04-21-2011, 06:13 PM Thread Starter
ok local shop here just told my buddy if he gets the bigger throttle bodies his power commander will work to correct for the bigger bodies
post #4 of 18 (permalink) Old 04-21-2011, 09:22 PM
Yeah...what do I know....I've only worked for the manufacturer of the throttle bodies for 20 years. (And have built a few prototypes...)
Power Commander will fix the intake for you
The duty cycle of the first generation injector (6 stream) is different than the 2nd generation (12 stream).
I will agree that your fuel burn could get better but still not efficient air intake to get the performance you are seeking.
My mistake.
post #5 of 18 (permalink) Old 04-21-2011, 09:34 PM Thread Starter
My mistake.
wasn't doubting u. I told him I was gonna ask on this forum before we did anything to his bike
post #6 of 18 (permalink) Old 04-21-2011, 11:11 PM
Quoted: 37 Post(s)
Nice, madbuyer....pretty cool knowing you have that insight into those throttle bodies. i may have a few questions for you in the future.
gts455 is offline
post #7 of 18 (permalink) Old 04-27-2011, 05:06 PM
VeteranRC51's Avatar
So I have a question that in all my searching has not been asked yet or answered. In reference to using a Moroki/ Thorston/ or Turn One Airbox that is obviously lighter and adds more usable air to the engine to suck whenever or especially when you pin the throttle; what about taking the whole airbox out of the equation and just having the filters sitting directly over the throttle bodies? If you need to make an adapter out of hose or "intake tubing." Would this be a prob? The only thing that I can think of is that the there is no "Pressure" built up......but there is also no real restrictions either, Cause no matter how big the airbox is, its still limiting in size, thats why were wanting to replace the orig airbox with the carbon airbox. Just a question, know I'll get sht from the experts.....
VeteranRC51 is offline
post #8 of 18 (permalink) Old 04-28-2011, 12:19 AM
Quoted: 37 Post(s)
you have to have a seal to create in there, other wise you will have air leaking out from everywhere. A loss of airbox pressure is a loss in power....a significant loss. Even though many forum guys have he Thorsten/Turnone/SS open airbox style it still has a rubber seal to create that pressure and in fact its been debated that these open style airboxes are not ideal for factory works spec racers because extreme braking and cornering can cause frame flex and a break in that seal and loss of airbox pressure and power. That is why the Works bikes and Moriwaki bikes all utilized a modified airbox but it still maintained a cover ike the oem box.
gts455 is offline
post #9 of 18 (permalink) Old 04-29-2011, 04:31 AM
I have questions. If they are both the same displacement, intake exhaust have small differences, they make about the same power (delivery is different), they flow almost the same air, how can they be spraying do much more gas? Is the fuel flow of the one different than the other?
If they used so much more gas they would either use much more air and make more power or flood and not burn the gas.
I thought the increase in injector holes improved atomization not flow. The throttle size only improved throttle response not air flow. It is almost like a venturi where the butterfly is at a larger cross section having a more accurate range of throttle control of the flow than when in a smaller part of the venturi (velocity stack).
Air/Fuel ratio x flow rate x efficiency = hp
ZeroGara is offline
post #10 of 18 (permalink) Old 04-29-2011, 04:38 PM
Yes, your term is much better. I put it in simple folk talk like.
I wasn't trying to turn this into a physics lesson either....
